Using the Spyder Blue Tooth
I bought and installed the communications module, harness and bluetooth accessory from my dealer. What does the bluetooth module do (it fits in line in the communications system) and what do I have to do to use it in the system? I have the garmin 660 with bluetooth, phone (Samsung Droid) and I have the head set so I have everyting needed except knowledge.
Thank for any help,
Randy
You connect your phone to the Bluetooth in the gps and make calls that way with the headset
You need to get each device to synch to your headset. The instructions for each unit should cover it.
Bill
Pride Runs Deep Semper Tacitus
An armed man is a Citizen; an unarmed man is a subject....
2017 F3 T SE6
2015 Vulcan Vaquero ABS
ALR Chapter 401 (Hilliard FL)
GA & FL Patriot Guard
Ok, got it to work last night. Is there a way to stream media from the phone to the headset via bluetooth...(Pandora for example?)
