Results 1 to 12 of 12
    Dec 2011
    Bonita Springs, Florida
    Default Want to hook up battery tender connector
    I went through all the posts I could find, looked at the manual and not being the brightest mechanic around still can't figure out how to get to the battery. I purchased the battery tender junior and the connector that attaches directly to the battery and want to install it on the battery to be ready for when I depart for a few months.
    Very Active Member freebob's Avatar
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default battery tender adapter
    Quote Originally Posted by Alberts46 View Post
    Just order the power outlet adapter and plug in power port in trunk on RT
    http://www.amazon.com/Deltran-Batter.../dp/B0024X2SC4
    Freebob...
    Invalid Emails
    Jan 2012
    Louisville Ky
    The best way...
    Active Member guinness's Avatar
    Jun 2010
    SEATTLE
    Default AGREE....
    Quote Originally Posted by freebob View Post
    Freebob...
    That's what I use on mine! Works great!
    Registered Users Grandpa Spyder's Avatar
    Feb 2012
    Portsmouth, Va.
    I bought my adapter at northern tool for $5.00. Plug it up every time I come in. Use the the trunk power port.
    Grandpa Spyder 2015 F3S
    May God Bless All Of those Who Serve Our Country
    Life is Good
    Link to all of my Mods with pictures, http://www.spyderlovers.com/forums/s...-with-pictures
    Mar 2008
    Allegan, MI
    To access the battery terminals to hook up a Tender pigtail, you need to remove the left side body panels. You do have other alternatives...either buy an adapter and plug in to the accessory outlet in the trunk (that's what I do), or use the alligator clips that came with your Tender and hook up to the jumper terminals under the seat.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Registered Users DynamoBT's Avatar
    Mar 2009
    North Hampton, NH
    I've got the Battery Tender Junior pigtails attached to my Spyder's battery. Once it's intalled, it is so easy to plug it in whenever I want. I don't have a power outlet on my Spyder. So, the tender pigtails is how I went. I'm not so mechanically inclined either. I had my deal install it.
    Marilyn
    Dec 2011
    Thanks for all the quick responses. I have the 12v plug adaptor but thought I read that wasn't the best method. Sure sounds like the way to go. Also read an old post you had to remove the left side body panels for battery access, thought it was a misprint, guess not.
    Thanks to all.
    May 2009
    Connecticut
    I have mine directly to the battery GS/RS model.
    Better to learn how to take off the proper panels and attach to the battery and run the connector under the seat.
    Lift the seat-Plug in at end of day!
    I,m saying the sooner you get Familiar with the panel removal the more maintenance you begin to do YOURSELF and SAVE lots of $$$?
    Sea Doo GTI-SE 90 Jet Ski!!
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Sarge707 View Post
    You can learn a lot just by doing.
    Registered Users Clicker1944's Avatar
    Apr 2010
    Cocoa, Florida
    I assume the 12volt outlet is active with the key off. I'm at work and didn't try it.
    2011 RTS SE5 Chrome Dash Kit, Best Flame Kit, Chrome handle bar end caps, Chrome Tail pipe tip and heat shield, Chrome Handlebar Cover.
    Dec 2011
    It is hot all the time.
