Want to hook up battery tender connector
I went through all the posts I could find, looked at the manual and not being the brightest mechanic around still can't figure out how to get to the battery. I purchased the battery tender junior and the connector that attaches directly to the battery and want to install it on the battery to be ready for when I depart for a few months.
battery tender adapter
Just order the power outlet adapter and plug in power port in trunk on RT
http://www.amazon.com/Deltran-Batter.../dp/B0024X2SC4
Freebob...
The best way...
AGREE....
Originally Posted by freebob
That's what I use on mine! Works great!
I bought my adapter at northern tool for $5.00. Plug it up every time I come in. Use the the trunk power port.
Motorbike Professor
To access the battery terminals to hook up a Tender pigtail, you need to remove the left side body panels. You do have other alternatives...either buy an adapter and plug in to the accessory outlet in the trunk (that's what I do), or use the alligator clips that came with your Tender and hook up to the jumper terminals under the seat.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I've got the Battery Tender Junior pigtails attached to my Spyder's battery. Once it's intalled, it is so easy to plug it in whenever I want. I don't have a power outlet on my Spyder. So, the tender pigtails is how I went. I'm not so mechanically inclined either. I had my deal install it.
Thanks for all the quick responses. I have the 12v plug adaptor but thought I read that wasn't the best method. Sure sounds like the way to go. Also read an old post you had to remove the left side body panels for battery access, thought it was a misprint, guess not.
Thanks to all.
I have mine directly to the battery GS/RS model.
Better to learn how to take off the proper panels and attach to the battery and run the connector under the seat.
Lift the seat-Plug in at end of day!
I,m saying the sooner you get Familiar with the panel removal the more maintenance you begin to do YOURSELF and SAVE lots of $$$?
Sea Doo GTI-SE 90 Jet Ski!!
You can learn a lot just by doing.
I assume the 12volt outlet is active with the key off. I'm at work and didn't try it.
2011 RTS SE5 Chrome Dash Kit, Best Flame Kit, Chrome handle bar end caps, Chrome Tail pipe tip and heat shield, Chrome Handlebar Cover.
