I Have Determined A Sawzall....
Is a girls' best friend!!
I have roots damaging my fence from the tree from hell behind me. I started excavating around the roots today. Got the sawzall running and zipped through most of the smaller stuff. Saved the big kahuna for tomorrow! The main root has to be a good 10 inches in diameter!!!
I have hated that tree since I moved in 11 years ago. It's dirty (drops seedlings everywhere), grows into the wires (affecting my phone service) and ugly as all get out!!! It's a hackberry tree. I have tried shocking it by cutting off all kinds of limbs and fed it Roundup---it's still alive!!! The neighbor behind me (it's partially in her yard anyway) had her kids put copper nails into it quite a few years ago. Sigh......
Every root that I did cut today, I tried to take a chunk of the root out--not just sever it. Then I fed it some more Roundup. Any other suggestions???? Short of cutting it down, that is..... It's half in the neighbors' yard behind me (and she wants it gone!!!), and half in the rental properties' yard next door to her.
Contact a tree service in your area. Have them cut it down and grind the stump out with a stump grinder.
It's better to make your own plans than to be part of someone else's.
If you both want it down, Use a chainsaw, won't take more than a few minutes.
Then rent a stump grinder from Home Depot.
The tree will have to come down if u kill it, so why wait?? Take it down now..If the tree is growing up through the phone/power wires, hire a pro to take it down.
**cough**cough**gas**cough**cough**
I had** 5 Box elder bug trees in my yard, and the neighbor has a giant one(4 trees 1 base). I got tired of the bugs and found the only way out was to cut them down. I waited till spring so it would have no leaves, but be warmer out. You can do it yourself with a chainsaw, just start by cutting all the main limbs off till you have the center trunk. Then... TIMBER!!!!
Then cut it up and burn it!
Or post an ad on craigslist.... Free firewood - you cut it and take it away.
If i lived near you i would cut that tree down for you in a few minutes, Every Spring i cut down 20 or 25 dead standing oak trees, drag them out with a loader, quarter them , Then when we have a work day at the club [May] i just sit back and watch the members split it all.
Copper sulphate can be pretty mean... We once watched an entire Lake full of trout die off because of a dispute between a couple of neighbors...
One of them dumped a bunch of it in there and that ended up getting the cops and lawyers involved and it was a real mess!
Originally Posted by vampyregirl
If you do use copper sulfate, [please don't] Make absolutely sure there aren't any wells or water nearby.
To kill trees you don't put it on the ground [roots].
So, I didn't have time to post earlier, but I did some research on the copper sulfate. PASS!!!! That stuff can be nasty!!!!
I'm going to try something tried and true: ROCK SALT!!!! Got plenty of that left over after our mild winter, so I don't have to spend any $$$$!!!! I figure it's worth a shot! I've already fed the damn thing enough roundup to choke a moose so.... We'll see.....
I still have to get the rest of the offending root out from under my fence......
problem tree
If the tree really does have limbs growing into the power lines the power company will def come out and trim it and probably be more than happy to totally remove the problem tree , saves them money in the end , at least in my case they did.
