Results 1 to 11 of 11
    Mar 2011
    Cheyenne WY
    Default tail light out....
    A little dissapointed in the spyders longevity of lights. I have had cars for more then 7 years without a brake/tail light going out. Its an 09 phantom with 8,600 miles on it and one of the tail lights are out I keep going back and forth if I should switch to an LED on both, or just replace with a normal light.
    Also, there was a thread showing how to remove and replace the light, but I can't find it. Can I get some help please?
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    LEDs only way to go. Put 25,000 miles on my 2009 RS with the NMN LEDs ( now Custom Dynamics )
    Happy Owner
    Mar 2008
    Allegan, MI
    Motorcycle (and motorcycle kin) taillights do not last as long as automotive taillights, in general. Same bulb, but the constant jolting of the lightweight vehicles is tough on the hot filaments, and they fail more readily...especially on rough roads. You can't use standard LED replacements, as the Spyder will sense the lower load as having the brakelights burned out, and will go into limp mode. Use of a load compensating taillight bulb or taillight conversion is necessary if you want to go that route.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Quote Originally Posted by Fly boy View Post
    I had one burn out about a month ago. I followed the instructions in the owners manual and changed it out in about 20 minutes.
    CAC
    Registered Users joet82's Avatar
    Oct 2010
    Winlock, WA
    Custom Dynamics' tail lights are AWESOME! check out my pics. Every light I have on my Spyder are LED, and all but the Fender Strips (TricLED) and the light where the license plate light used to be (Truck'n'stuff) are by Custom Dynamics....check my pics to take a look.
    RS - 55K+ miles, F3 - 200 miles and counting.
    Oct 2010
    Winlock, WA
    Custom Dynamics includes a "load equalizer" with their "all-in-one" accessory on the rear tail lights. I have had no problems with electrical flow in referance to the lights.
    Very Active Member Texmac1011's Avatar
    Aug 2009
    Granbury, TX
    After going thru many standard 1157 bulbs ( I learned the filament can't take the pounding)I now buy 1157 LED bulbs off Ebay for about $5 a pair and free shipping. I broke my tail light some time ago and replaced with a generic tail light from Autozone. All has been well for a long time.
    Ryde Safe!
    "There are two things you can never get back. A word after it is said and time after it is gone."
    Mar 2008
    Allegan, MI
    Quote Originally Posted by joet82 View Post
    Yes they do. That is one of the acceptable products.
    -Scotty
    Registered Users JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    If you have the rear seat option have fun getting to the bulb . I have the rear seat but I did a mod that was posted here showing how to remove a section of plastic located above the rear tire splash shield. Once this plastic has been cut or ground away you can remove the bulb by dropping the splash shield. I had a light go out last year at Spyderfest and it only took about 15 minutes to replace the bulb. Without this mod you have to remove parts of the rear seat mounting hardware.
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
    May 2009
    Connecticut
    Use 2357 Bulbs because their better and change the 4 T-30 screws to 10mm Torx head bolts and replacement will be a LOT faster.
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2011
    Cheyenne WY
    Quote Originally Posted by Sarge707 View Post
    HA, shouldn't have to replace them that often to do that!
