Turn signal
Does anyone know how to get to the turn signal bulb to replace it......thanks in advance.
I should have mentioned this b4.....I have the 2010 RT
Page 97 of owners book. You have a set screw in upper left corner. Unscrew it. Lens will fall out. Turn counterclockwise (bulb end).
Turn signal
I have the 2010 rt.........not on that page
Shop Manual
You're correct. It does not seem to be in the Owner's Manual. The Shop Manual on page 510 shows the procedure under the heading of Taillight/Brakelight replacement even though what they are showing is the turn signal bulb (the Tail/Brake lights are LED's and the entire unit must be replaced). Their procedure is to remove the "rear panel" which is the body-colored panel that runs up the side of the topcase and across the back of the bike around the latch for the top storage compartment and down the other side. Eight screws -- two accessed by opening the sidecase door and two by opening the top storage lid. Same for other side of the bike -- eight total. Remove the panel. Then reach in, unplug the connector, rotate the bulb socket counterclockwise to remove it, pull the bulb out of the socket. Reverse for assembly.
If you do it, could you post the SAE bulb designation you find on the bulb. I'd like to know what to have as a spare. Thanks.
RT and Gold Wing States & Provinces
