2010 RT?
Are the shims also for the 2010 models?
HokieV
2015 RTS Intense Red Pearl (New Jan. 2016) - Comfort Heated Seat w/Backrest, Custom Dynamics HMT Brake Light, superbrightled.com Brake Light Strobe, TricLED fender lights w/Blinker Module & Turn Signal Strips, Stebel Nautilus Horn, FOBO TPMS, Spydercuff, Dual USB outlet, Bike Barn.
Previous - 2011 RT Limited.
BRP Spec and Info
I had my 2011 RT-S shimmed in early January. The "Technical Service Tip" from BRP says this: "If the customer complains of vibration, first check belt tension. Second, check the clearance between the left-side front engine mount and the frame. Use a 0.04” or 1mm feeler gauge. If you can get this gauge to pass thru, then everything here is OK and not a source of vibration. If the clearance is less than 0.04”, then install the shims (0.08” or 2mm – part number 707001074)."
The "tip" shows a photo which is similar to the photos posted here in an earlier thread on the subject: http://www.spyderlovers.com/forums/s...ht=motor+mount .
I believe BRP began installing the shims at the factory part-way thru the 2011 year and for sure all 2012's have them. My tech charged about 5 hours for the job so it is not insignificant. If you're out of warranty I suspect the cost would be on you. But that's between you and BRP.
As far as your dealer not having any info on this, my dealer didn't either. He had to call BRP, ask the question, and then they faxed him the "tip" which includes the info above and the replacement procedure. There is no "tip number" or anything like that to identify it. Just the subject matter.
RT and Gold Wing States & Provinces
2011 rt motormount shims
gypsy_100 is right on, i have the belt tensioner, and a early 2011 rts
the tensioner did a good job eliminating belt vibs the shim finished the job
now lets work on gas milage and i will be a happier SpYder pYlot
John, I know this was quite a few years ago... but did you have vibration all the time? Just sitting in the driveway? Mine vibrates all the time and when riding OMG cannot ride more then 1/2 hour. I was wondering if the tech is still there? I am in Lebanon, ME, not far from there.
John's last post was in 2019 .... try and e-mail Him ..... Mike
