Signal Dynamics BackOFF Brake Hold Module Install
Can you install one of these modules on the Spyder if so how do you do it?
Guess the answer is No.
The module needs a Pulsing (square wave) Speed input (0-12 volt) usually on a transmission VSS (Vehicle Speed Sensor) that is a hall effect type (three wire) sensor. The Spyder has no such sensor, I can only see the Wheel Speed Sensors for the ABS/VSS/TCS system, the computer must get all the data from them for the speed reading. The wheel speed sensors on the spyder are variable reluctance sensors (Two Wire) and are analog signal at very low voltage and need signal processing to get a digital speed pulse. They are used because they are reliable proven technology, very rugged to harsh conditions and inexpensive sensor.
Blazing Member
While the good news is you can still keep your hands free when stopped, the bad news is you can only put one foot on the ground .
Tags for this Thread
