Best Mod for $100-$200?
Seems like I am off to a good start, but....what is your favorite mod for under $200?
"THE DOG SLED"
2011 Spyder Can Am RTS SM5 (Orbital Blue)
Nuvi 550 GPS With Ram Mount
Drink 2 Go Cup Holder
KewlMetal RT Run-Turn-Brake LED
GloRyder Wolf Paw (in blue)
DMWMS Decal
IPS w/
Alaska Leather Sheepskin Butt Pad
TricLed - Brake Pedal
Blazing Member
Any TricLeds, ESI brake light, ISCI Flag mount ,Power Sports Wraps Dash Kit, Baker Airwings
Stuff in the $200 range... The top trunk and Frunk-liners give a nicer finished feel to the bike...
My best mod would have to be filling the spyder up with fuel cost $25.00 and leaving the wife at home"
kew metal air cleaner, juice box pro, fan regulator, 02 elimiator,afr gauge, oil presure gauge, bar riser , ikon f & r shocks,sway bar.custom drilled rims with 205/40/16 new engine at 10000 km's, larger frount brake rotors,Yoshi R3 ss exhaust, custom candy orange with air brushed spiders
now removed kew air cleaner, o2 elimiator, custom wheels and yoshi. runs better with out you live and learn they say, and if its not broken don't replace it"
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
Baker Air Wings & Digital Voltmeter are the two primary mods that added the greatest functional value to me. I have probably 5-6 more sub $100.00 mods, but they are more cosmetic in nature.
Alright....mine is a few dollars over the $200 mark at $215. Utopia backrest. I would rate this as one of my best spyder mod/upgrade!
** Loving my 5th Can-Am Spyder since 2007! **
Originally Posted by akspyderman
Glo Ryders
I have the wolf paws in blue already. I do agree though excellent mod and customer service.
Jim
"THE DOG SLED"
DMWMS Decal
IPS w/
Baker Air Wings, hmm....are they easy to install? First ride I have ever owned without lowers.
"THE DOG SLED"
DMWMS Decal
IPS w/
IPS key cover.....or....... SPYDERPOPS bump-skid plate. For my area I think the plate will be the best investment.
$200 mod
i have an 08 GS, i took off rear CORBIN seat and mounted a fiberglass tour pack from an older motorcycle. this gives me about same amount of storage as the FRONK. did all the work myself except painting.
Very easy install. Replace a stock bolt with a bracket bolt, attach a plate with adhesive backing to the top of the Can Am logo on your lower panel and that is it.
ESI (Custom Dynamics) Fender Tip System $64.99.
You can add $10 Mud Flap and Side lights from different sources but You need the fender tip system to make them blink~!
Sea Doo GTI-SE 90 Jet Ski!!
Motorbike Professor
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Shorty antenna (with US flag attached), coffee cup and holder. Nothing else is necessary…..
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
$100-$200 MOD
SPYDERPOPS Bump Skid and Lamont's IPS key fob !!!
2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
Thanks...
"THE DOG SLED"
DMWMS Decal
IPS w/
Street Magic Genesis LED RT HMT Brake Light . Best See Me, See What I Am Doing for these $$$.
MODS FOR $100
My $65 risers aren't enough to make the qualifer ....so I got nuttin......Mike.......
Originally Posted by NancysToy
Fifty gallons of gas!
I notice that you didn't mention leaving Nancy at home... Like Darren did with HIS Missus!
All this time over the past 2 years looking at...and adding farkles...and somehow I overlooked Lamont's IPS...How'd that happen?
