Results 1 to 12 of 12
Thread: ptt button
    Invalid Emails
    new lisbon wi.
    Default ptt button
    I don't know if anyone else has had this problem but everyone I ride with says when we are talking on the cb that my ptt doesn't clear when releast. I've sprayed the button with contact cleaner but it doesn't do any good. If I flip the switch a second time it clears. Any help would be great.
    Very Active Member stevedfive's Avatar
    Aug 2010
    Riverside, California
    With the 2010 RTs, BRP replaced the cluster to correct the problem.
    2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
    Invalid Emails
    new lisbon wi.
    Default ptt
    does brp back this problem?
    Aug 2010
    They did on mine.
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    On the 2010 models there is a programming problem that causes the problem. They corrected it on the 2011 RT. The fix is to swap the console display assembly with a 2011 model. Mine was covered under warranty.
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    Aug 2010
    What he said. Ha.
    Invalid Emails
    new lisbon wi.
    Default ptt
    Thanks for the info, I'm taking spyder to the shop next week and now I have something to go with.
    Jun 2009
    Snellville, GA USA
    If your dealer doesn't know about it, have him call BRP. It is not a recall since there are relatively few RTs with the CB installed. They only warranty them when there is a complaint.
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    Danbury Connecticut
    Quote Originally Posted by gary lester View Post
    One small point. The odometer is in the cluster. When the cluster is replaced, the total (not the trip odommeters) mileage shown is reset to zero.
    You need to keep track of this for determining maintenance intervals and mileage awards such as pins or patches.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member wtwing15's Avatar
    Aug 2008
    Canberra ACT Australia
    Angry ptt button
    Quote Originally Posted by stevedfive View Post
    Hi all I have been having the problem with my ptt button for a long time , but BPR Australia dos not believe me when I told them about the fix over there
    I would like to know What Calos full name is and position he holds at BPR and a contact number. I think if I supplied this information to the nutheads over here I might get my ptt fixed
    Thankyou From Australia.
    My will reads "being of sound mind and body,
    I spent it, go make your own!"
    VERY HAPPY SPYDER OWNER.
    Jun 2009
    Snellville, GA USA
    Quote Originally Posted by wtwing15 View Post
    Take a look at this link: http://www.spyderlovers.com/forums/s...r-Support-Link
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    Aug 2008
    Quote Originally Posted by MarkLawson View Post
    Thankyou for your speedy reply
