SpyderLovers Founder
Looks like they had it right to start with
Fred Rau posted this pic on facebook of the clay RT and trailer. Notice they had stock front wheels on the trailer. Wish they would have kept it that way so you could carry one spare that would work with the front of the RT and the trailer.
Glo Ryders {4 sets (Blue, Red, Orange, Pink) I swap out}
Rear Trunk Liner ......... Seal Floorboards
Rear Trunk Shelf
Corbin Heated Seat
extra 12V plug
Elka shocks
White/Red fender lights
Bump/skid
Baker Wind Wings
Honey Burl Dash Kit
Motorbike Professor
My suspicion is that the trailer got caught up in the regulations, and the three lug wheel was not legal under the current regulatory structure. It might be possible to get the weight rating and "axle" certified, but it would take time and $$$ at very least. This is the easiest way out in that case. Also remember that the Spyder tires are taller, on 14" wheels, so the trailer would sit higher...and the added unsprung weight from the taller wheels and wider tires would affect the suspension needs and the handling. The RT-622 is pretty darned perfect in that department, so I am not sure of a good reason to mess with it. Not sure of the wisdom of carrying a spare for the front of the Spyder when the rear isn't the same, either. JMHO
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I would think if they could get away with a swingarm mounted hitch on the Spyder a three lug hub would be no big deal. There are plenty of trailers that ride higher than the RT trailer too so I don't see that being an issue. I guess the point of carrying a spare for the front and trailer would be four of the five wheels you're using could be used as a spare if needed.
Perhaps stability concerns overcame "ease of use" issues...
Larger wheels handle better. My Bushtec had large wheels on it and it handled great. My guess is cost, the trailer still has the same size cutout for the larger wheel but my guess is going with the smaller wheel and tire cut the cost quite a bit..
Blazing Member
This might be splitting hairs given the difference in wheel sizes, but wouldn't larger wheels raise the COG and make the trailer more likely to tip over?
If it was a straight axle maybe but with a trailing arm setup it would have little effect and could be adjusted to sit lower.
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
Since BRP decided to use a six spoke wheel on the RT they could have used a six lug wheel for the 622 on the same bolt circle and it would have fit the Spyder as well. Some of aftermarket wheels have multiple holes for different bolt patterns.
Just a thought.
"Stupid is as Stupid does"
Don't Drink and Drive or Ryde!
Each Day is a Gift
RT-S PE#0412
These would be great questions to ask BRP in Durango and hear it from the engineers as to there reasoning. and why the trailer doesn't come with chrome wheels
Motorbike Professor
-Scotty
RT-S PE#0412
I would have thought from a production standpoint it would be cheaper to use an existing wheel---- literally why reinvent the wheel--- lol
Would make sense for a spare too. If I was to carry a spare for the Spyder it would be a front. 66.7% chance of front blowout vs 33.3% rear.
I do carry a spare for the trailer.
Always cool to see the clay models.
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
I don't think they will sell very many in that color.
Motorbike Professor
Don't worry, it looks just like Lava Bronze after they apply the clearcoat.
-Scotty
RT-S PE#0412
I too carry a spare for the trailer and have ride on in the rear of the spyder, next time will get it in front also. They (dealership) said the RT 622 tires were too small & not recommended to put Ride on in them .
Motorbike Professor
I heard that, too, but the Ride-On tables have a volume for that size tire. I have been running Ride-On in my trailer tires from the beginning, with no problems whatsover.
-Scotty
Went to Walmart and found a spyder in a can.
Now I know where they come from.
