Forrest, glad you made it.....
Private joke maybe??
GREAT movie though!
3 Throttle body failures and looks like 4 is bad also.
I hope you get it fixed - you don't want to be called the Incredible Mr. Limp Mode.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
SpyderLovers Founder
Is there any thing that triggers this that you can think of? Does it happen at start up or driving down the road? I'm sure BRP would like to figure this out as much as you would.
I have a theory. Forrest, when you shut your Spyder off, do you use the kill switch first then ignition or just the ignition?
My theory is if you use the ignition first, the throttle body plates are not held closed for as long as they should be resulting in the throttle body failures even after the update.
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
I would think (hope) after 3 of them have gone bad that something is causing them to go bad. Its going to take more then a parts replacer to figure it out.
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
The reason I mention this is someone posted about the annoying noise that occurred after they shut down their Spyder and they figured out a way to make it stop sooner.
I routinely use the Kill Switch.. However, that is not 100 % ..... maybe 98.99 % of the time.
Thanks Lamont.
I wonder just how many times that all have had the same issue and what BRP thinks is causing the problem?
I know I am not the only one who has this issue.
