exhaust leak?
Need advise on a strange sound from the muffler. Sounds like there is an extra pop once in a while the hotter the bike, the more frequent the pops, none when cold. Recently replaced the plugs and wires, the pop was there before the plugs, idles fine(RPM stable), performs fine, engine sounds fine, just at the exit from the muffler I hear and feel that pop and only when I am sitting at the red light or at hot idle. Y gaskets replased under warranty at 5200 miles with BRP gaskets, Now 10500 miles 2008 GS SE5. Any Ideas? Time for Honda Gaskets, new muffler?
Thank you for your time
Motorbike Professor
If the Y-gaskets were replaced under warranty, they were stock gaskets. They are probably shot again. Replace them with Honda gaskets and they'll last much longer. There are other possible causes, but this is the first thing I would look for.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Stock gaskets don't last long. Hondas are the way to go.
Honda gaskets # 18392- MAM- 000.
I just did this myself... the stock gasket on the right side was completely disintegrated. Replaced with the Honda gasket. The only problem occurred when one of the screws for the cover under the seat fell between the brakes and the wheel... took 15 minutes to dig it out.... LOL
Thank you everyone for pitching your thoughts
