I'm so impressed and grateful for all your comments... Lots of excellent advice.
I've been pondering about what factor(s) could have made me feel uneasy the other day on the highway, and I've listed the things I think I need to examine:
- Spyder instability. Not likely, I feel my RS is very much like "on tracks". The aftermarket swaybar and Elka shocks help a lot.
- Wind buffering. It used to be a bigger factor until I put a 22" Madstad, now unless there is a strong cross wind, my head and upper body feel well shielded.
- Spyder vibration. My teeth are not rattling and parts are not falling off. I have added Captain Jim's tensioner. I also have top notch antivib grips and pegs. That said, the Spyder is not as smooth a machine as my former BMW. I have to get used I will never will be able to cruise, and cut the wind at 100mph, like I used to with my 1200GS.
- Power. No problem here, I find more than I need. I also have installed a HMF exhaust, a O2 modifier and a better flowing air filter. My Spyder is strong and fast. A 6th gear would probably help to smooth power delivery at higher speeds.
- Noise level. I think this is what was getting to me. My HMF is a lot louder than the stock pipe. That Rotax engine revving above 6000 rpm, can really roar. Nevertheless I prefer a loud bike than a stealth one. I want my presence to be known for my own safety. I have to learn to appreciate and get used to my loud Spyder.
These realizations, along with all the good pointers posted in this thread, should help me feel more comfortable the next time I get on a highway.
Cheers.
Interesting. I have a 2012 RT
Originally Posted by NancysToy
I ride the slab a lot. Fortunately, around here, the speeds are a little slower. I usually stick to about 75-78 as indicated on the speedo, which is around 72-75 in real life. The speed limit here is 70. At that speed, I pass more cars than pass me, but I do get passed. I do this whether on the RT or the RS. As has been said, ride at a speed that is within your comfort zone. There is no sense in arriving at your destination a nervous wreck. The sensation of speed is much greater on an open vehicle, and it can be unnerving to some...especially those new to open-air riding.
If your Spyder does not feel stable at speed, it may be time to get your alignment and steering sensor calibration checked, as well as checking the air pressure in your tires. A Spyder that has problems in those areas can feel unsteady at high speeds, but a Spyder that is properly set up is quite stable at pretty high speeds. They will handle triple digits readily.
That just brought to the dealer for its first 600 MI check up. I explained there was a 'vibration' I felt in the 28 to 34 mph range, disappear, and come back in the 67 to 74 MPH range. The dealer was unable to verify the condition, and sez they could not find a problem. but perhaps I can ask about if the 'steering calibration sensor' was checked.I am new to the spyder experience and their idiosyncrasies. I'm ordering the 2012 shop manual (not available yet for $100 from the dealer). But thanks for some ammo to go back to the dealer with.
Motorbike Professor
Originally Posted by zbunker
That just brought to the dealer for its first 600 MI check up. I explained there was a 'vibration' I felt in the 28 to 34 mph range, disappear, and come back in the 67 to 74 MPH range. The dealer was unable to verify the condition, and sez they could not find a problem . but perhaps I can ask about if the 'steering calibration sensor' was checked.I am new to the spyder experience and their idiosyncrasies. I'm ordering the 2012 shop manual (not available yet for $100 from the dealer). But thanks for some ammo to go back to the dealer with.
A steering sensor that is not zeroed may cause instability or steering issues, but it will not cause vibration...unless it is so bad the tires chatter, and you'd know that for sure. Possible causes for vibration include too little air in the tires, tire balance/truing issues, inadequate engine/thrust rod clearance, belt tension, too low rpm, and the most common...normal V-twin engine harmonics. I'd take a closer look at the rpm you are running, what gear you are in, and where you are shifting. I don't know what you rode before, if anything, but a lot of folks have to adjust to the higher rpm of the Spyder engine. It is possible you are lugging the engine slightly, or are just in the range where the engine harmonics are the worst. The Spyder is happiest at 5,000 rpm or more.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
HIGHWAY
Recently on Rt 20 heading into Jackson Missouri t[f you weren't doing 80+ in the slow lane you'd be run over. So I was 80+ when the wife tapped me on the shoulder and asked "how fast are you going". At that moment an 18 wheeler was passing me and I said "apparently not fast enough". No I didn't speed up but it was exciting to say the least. We by passed Rt 20 on the way back!
MOgang Member & Monster Member
Gunk. If you came thru Jackson you weren't too far from me. Not sure about Hwy 20 though. Im not familiar with that one Maybe it was Hwy 25? Anyway if your ever through this way again give me a shout!
Reason: signing name
