HELP PLZ!!! Exhaust issue
I have an '09 GS. A few months ago, I took it in for the 9k service. When I got it back, it seemed I could hear what could be a minor exhaust leak. I didn't make too much of it because the shop just had it. Well, it seemed to get worse and the mc seemed to lose a little power (I generally ride it everyday to work (45miles each way), plus shopping, etc.). It finally got loud enough that I decided to park it until I could track down the leak. Well, I found a pretty good leak on the right side at the exhaust connector. It looks like there is a small amount of heavy gauge steel wool inside the ring of the connector (I'm guessing to allow it to be tightened further). The leak itself (which I would describe as pretty severe) is where the ends of the sleeve meet. I'm no mechanic, but as far as I know, there should be no leaks anywhere along the path from the engine to the muffler. I tried tightening it down as much as possible, but it still leaks. Any suggestions? I appreciate any help, because I'm stuck with the cage until I resolve this. Thanks!! BTW, the leak is aimed right at the engine housing.
It sounds like your exhaust gasket is shot. No big deal and a easy fix.
Click link under my signature to take you to a thread that will show you how to change them. Get the Honda gaskets as explained in my videos.
SpyderLovers Sponsor
Very common. It is surprising that your shop did not catch this. Replace the gasket and you'll be good to go.
Yep, Honda gasket's You need two, # 18392-mam-000.
Just remember to burn them in properly. After install run your spyder up to opperating temp and at least 15 minutes. You will smell it burning. Yukky odor.
Then shut it off and let it cool. Then tighten your 10 mm bolts some more.
Thanks so much Arntufun!! After I removed the exhaust, I found that sure enough, the right gasket was completely non-existent. The left one appeared ok, but I'm going to replace it anyway while I have it off. My issue now is tracking down the parts... where I live, that means a lot of driving around ! Oh well... Thanks again
Get them on line, hete you go for one source:
http://www.cheapcycleparts.com/model...ssemblies/7329
Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
I have a half dozen sets if you can't get them quickly just let me know
Thanks Firefly, I figure if the local guy doesn't have them, then I'll just order them from the Honda MC dealer, but he's about an hour from my house, but I'll have to wait for until next week to install them in that case. I'll get a few sets, now that I know the deally... thanks so much!!!
I have ordered a RTS but have not received a serial number or ship date yet. My son works at a Honda dealership a couple of hours from here. He got me two pair of gaskets, haven't picked them up yet. I will be prepared.
Why two pair? Just in case.
Good idea Lorne! I just went to the Honda dealer...over an hour away from me...and ordered two sets. Now, my Spyder sits, naked, with parts all over my garage, awaiting the necessary RX!!! I miss my Spyder... I need ice cold air streaming over my knees and landing on my crotch!!! I can't wait to get it up and running again!!
You are probably right, at least I hope you are. But if I screw up installing one or both of them, I will not have to drive three hours round-trip to get a replacement.
There are two other Spyders in town here, so I am not worried about getting rid of any extras.
