Page 1 of 2 12 LastLast
Results 1 to 25 of 38
    Aug 2007
    Springfield, MO
    Default Possum Pusher installed today
    That's not what SpyderPops calls it's but that's what I call it.
    I finally had some time to get this mounted and like those have said it looks like it was suppose to be there. I only have about 1600 miles on this RT and I already show some roadrash on the bottom side that I didn't know I had. I think this will save my bacon on those low speedbumps and those little critters that tend to pop up out of nowhere
    Roadrash before the install
    Looks naked without it now
    Mar 2008
    Allegan, MI
    It really accents the look of those black flames.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Jul 2010
    Arkadelphia, Arkansas
    Default bump skid
    Bump Skid looks nice on that white. Looks factory!
    Registered Users DynamoBT's Avatar
    Mar 2009
    North Hampton, NH
    Pretty nice!! Sure does look like it belongs there!
    Marilyn
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Possum Pusher certainly should be the official name in Tennessee
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    MOgang Member & Monster Member
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    Looks great!
    I can't wait to install mine!
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    Did you install in place or did you remove the trunk?
    Thanks
    Randy
    Aug 2007
    Springfield, MO
    Quote Originally Posted by bluestratos View Post
    Thanks
    Randy
    It installs in place.
    Nov 2010
    Norway, IL.
    Put mine on a few days ago. Now if I had a plow up front I could ride.
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    Quote Originally Posted by Lamonster View Post
    Any holes need to be drilled or does it use existing mounting holes? This mod looks to be on my list this Spring.
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Y Rider View Post
    There are four indexing holes that you use to drill the front holes. You do have to drill the front holes.
    Invalid Emails
    Mar 2011
    NE TN
    Now that, I like. Your pics showed me what I hadn't seen on SpyderPops. Thanks!
    Registered Users SpydherLuv's Avatar
    Mar 2011
    Fair Oaks, CA
    Looks really nice! I might just have to get one for Libby after bottoming out during a ride over the weekend.
    Active Member LarBear4442's Avatar
    Jan 2012
    Estes Park Colorado
    Default Install In Place
    Would you please explain the meaning of Install In Place............thanks
    Very Active Member napper39's Avatar
    Jul 2010
    kansas ottawa
    with out removing any thing just in stall.
    Dec 2011
    Buford, GA
    Thumbs up Pssum Pusher
    Certainly applies to Georgia. Will look to get one installed in Cuba. Looks good.
    SpyderLovers Sponsor
    Jun 2010
    Las Vegas
    I think I need one, my new driveway looks a little steep.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Registered Users trxrspyder's Avatar
    Jun 2011
    Central Pennsylvania
    Any plans for an RS version?
    Invalid Emails
    Jul 2010
    1/2way tween STJames and Salem Mo
    Question
    I have led lights under there what about those? have to remove them? or move them?
    Invalid Emails
    Mar 2011
    NE TN
    Quote Originally Posted by trxrspyder View Post
    Yes, see Spyderpops answer here.
    SpyderLovers Sponsor SPYDERPOPS's Avatar
    Oct 2007
    Pearcy, AR
    Quote Originally Posted by ThreeFeet View Post
    There's always a way! Are your led's on the stock skid plate or just on the frame?
    Invalid Emails
    Mar 2011
    NE TN
    Default Next...
    Lamont had me with "Possum Pusher", it totally makes sense (but will it hold up to armadillos?). Where will this end? Roo Bars, Raccoon Racks (oh, no, Bob is getting that from Inspector Gadget).
    Sep 2011
    North Central Illinois
    Two questions before I drill...
    Is there a specific drill type and technique that should be used to drill the front holes into the Spyder body? I don't want it to split or something.
    Secondly... can the skid-plate be polished? Mine isn't as clean or smooth of a look as I might have expected due to scuff-marks and things that were on it when I received it. These marks will show when I put it on. (Even on the top-side which is the side that will show around the front edges.)
    Thanks for any input on this.
    SL #7026
    VBA #652
    HOG #3935417
    2011 Viper-Red Spyder RT SE5 & Trailer
    2017 HD Ultra Limited
    Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
    Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
    Registered Users JCSMOKE's Avatar
    Sep 2011
    Johnson creek. Wi
    Quote Originally Posted by Illinois Boy View Post
    1/4 in drill bit works fine, sharp bit works better. My suggestion, and I would have done it this way if I knew to do it this way, get the thing in place with the back bolts and drill a way up front hole. Then put the clip on and screw it in to keep it in place when doing the other holes, I had a couple that for some reason where not quite right. No ideas about polishing, but if it's bad I'm sure he will replace it fast. This is an easy to do 1 man job, and if you want to bling it up a bit there is a bit of a gap between the bumper and the skid plate that is yearning for some LEDs.
    Corbin saddle
    spyderpops block off plate, bump skid, belt guard
    IPS
    Tricled LED lights all around(too many to name here)
    Smoothspyder belt tensioner
    Custom Dynamics britesides
    VTC floorboards, upper air vents, spoiler
    BK car stuff HID upgrade
    trailer hitch
    Repainted rear fender, trunk latch assembly, switch cluster, gauge cluster
    cell phone interface kit
    travel cover that no longer fits due to the spoiler
    New sway bar
    New shock relocator
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Yol Bolsun View Post
    Don't forget "Squirrel Squasher".
    -Scotty
