Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    Default Fluid temp vs MPG
    I've been noticing lately that the colder my water temp is the more fuel is being consumed. And of course when it is warm the less. I know on cars there is a sensor to richen the fuel mixture so to warm up the vehicle quicker. Is it the same on the Spyder? Yesterday, I went on a PG mission "down the hill" which has been enjoying 80 degree temps lately. My temp gauge on my RT showed rough half way. I drove about 120 mi and got about 35 mpg. Coming home in the desert the outside temp was in the 60's, my water gauge showed about 1/4 up (analog), and I got about 28. Why? Also, last summer I added a little "Engine Ice" to my fluid because of the high temps out here in the desert. But in the winters, when the temps drop below freezing and stay in the 50's during the day, my fluid temp may barely show any rise at all when cruising on the freeway. And of course the mpg drops. So whats going on here? I'm sure there are many owners out here who may be in the same "boat".
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    Very astute of you to notice the fuel economy change correlation with the temperature change!
    I'm not sure if it's the fluid temperature or the air temperature that enrichens the mixture to keep things happy, but I'd guess that it's the latter.
    Quick mixture Primer...
    Cold, denser air requires MORE fuel to keep the mix correct
    Warm, less-dense air requires less...
    That's why we get better fuel economy in the summer!
    Mar 2008
    Allegan, MI
    While mpg does vary with the air temp and density, there are too many variables here to attribute it all to the temperature. Which way was the wind blowing? How strong? Minor variations in filling the fuel? Different fuel from different staions? Uphill one way? All these can affect the mpg you calculate, especially over just a couple of fills. Gas mileage almost always is different in one direction of a trip compared to the other, due to the wind and the elevation changes alone. Only a long term, controlled study can prove that what you suspect is actually true.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Aug 2007
    Greeneville, TN
    The Spyder's temperature gauge is much more sensitive than the average automobile (or other motorcycle gauges). What appears to be a big swing in temperature is not all that much. The coolant system thermostate keeps the engine temperature to at least normal operating temperature.
    I am doubtful that this is the reason for your mileage change. I usually find mileage is better with colder outside temps, which makes sense because cold air is denser and gives a better charge to the cylinder. But this is a generalization and other factors have much more effect.
    Default AIR TEMPS
    IMHO, Colder is better power wise anyway....back in the day I knew guys who would put ice in the air cleaner housing for that little extra ???....Mike ..........
    Spyderless Member
    Dec 2008
    north/central n.j.
    Don't know about the air cleaner but, Back in the 60's i made my own cool can's, I would Spiral a few feet of fuel line in it then fill with ice. Kept my ET,s down in the summer at the strip.
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    Yes, we used to solder in a copper coil in to an old tomato juice can that we filled with ice. it helped on the quarter mile but no differnence on trips. Not sure if I remember this correctly but I believe the cold gas takes up less space than normal or hot fuel so when the fuel enters the cylinder it expands, taking up some of the space. This resulted in a bit richer run off the line so I believe we used to compensate by leaning the air/fuel ratio bofore the run (for the street rods). Cooling the air technically would have the reverse effect, ie allow less room for fuel but with modern knock sensores, oxygen sendsers, electron timing control and all the other goodies the air temp should have little or no effect. The winter blends of fuel do make minor impacts on fuel milage both gas and diesel. It is more notible in diesel, my 2005 F250 drops from 16 in town to 14 when the winter fuel enters the scene.
    Regards,
    Oct 2008
    Barstow, California
    Wasn't there an old trick on the two barrel carbs of putting an orange peel over the throttle bottle to prevent vapor lock?
    Happy Spyder Owner
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Desert Spyder View Post
    Throttle bodies, Replaced Carburetors .
    Quote Originally Posted by boborgera View Post
    Question: Throttle Bodies... Aren't there more advanced systems being used today to get the fuel and air into the compression chamber??
    Spyderless Member
    Dec 2008
    north/central n.j.
    You might be thinking of direct injection, but they still need some thing to get the air mix in.
    Just about any [road] vehicle you can buy comes with throttle bodies,.
    That said there will always be advanced systems coming along every day.
    Awhile back there was a guy in India who was running a small car with an air compressor.
    The cylinders were pushed by Compressed air, The compressor was run by a Kerosene? generator.
    One day some nut will come up with a billion dollar idea. ie; Remember Edison
    I like the way that you think, Mike!
    But I guess I was thinking of something that us mere mortals could use without having to get too "mechanical"...
    Default COOLER IS BETTER ??????
    Mike in Ga. You are absolutely right......In Antartica my Boss "429" with the shaker hood would't work worth a damn......Ford just couldn't get that right.....or the Talledaga either...........Mike...
    Are you sure that wasn't the extra thick oil in the pan not allowing ti to spin over quick enough??
    Registered Users Campverdefela's Avatar
    Aug 2009
    Camp Verde, Az.
    Yeah, but then the oil co.s put a hit on them
    Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by HDXBONES View Post
    Sorry Mike, but you're off a bit.........
    Cold, dry, air at sea level is the most dense, with the highest oxygen content. Air with a high moisture content is less dense, as the water vapor molecules displace the air molecules, resulting in less oxygen available for combustion. Hot, humid air is the worst for performance, and dew point isn't really a factor....
    Colder ambient temperatures will result in the Spyder's ECM increasing the fuel delivery to the cylinders because of the added oxygen available. This would result in better performance, so theoretically, the MPG should balance out. The mixture isn't 'richened', the fuel/air ratio would stay the same. Having fun with the increased performance might result in an MPG reduction.......
    Ahh... Reason, reality and proven fact.... You don't stand a chance with this approach!
    Mar 2008
    Allegan, MI
    Well, I don't completely agree with either of you. Here is my understanding of this, partly gleaned from many years of racing.
    Cool, moist air is the most dense, but moist air does not hold as much gaseous oxygen per unit volume, so it may not work the best. The oxygen (and hydrogen) in the air are not usable in the combustion process. The water is merely turned to steam. Too much moisture and the engine suffers. A little is good, though. BTW, if engines could run on the hydrogen contained in water, we wouldn't be using gasoline.
    The EFI will adjust the amount of fuel delivered to match the fuel/air ratio called for by the mapping. Denser air requires more fuel to keep the same ratio. The actual volume of air taken in remains constant, as it is a product of the volumetric efficiency of the engine, but the amount of oxygen is greater in the denser air, so more fuel will be required. (Note: engines with variable valve timing can change the charge volume.) You will generally use a bit more fuel at lower altitudes and higher air densities, as a result. Other variables, like fuel mix, grades, wind, and the fuel composition will affect the mileage, too, often far more than mere air density. As was said, the peppy feeling you get from having a bit more fuel in the denser intake charge, often results in involuntary twisting of the throttle, which makes the most difference in your fuel mileage.
    So, here we are with three somewhat different slants on the same phenomenon. I won't say which of us is right, if any, but I will say that I have not been convinced enough to change my understanding of the process. JMHO
    -Scotty
    Aug 2007
    Greeneville, TN
    After spending 33 years in the fire service I can say that I've put water on a lot of different kinds of fires, and it never burned one time. There are some fires that you don't want to put water on (like a petrolium fire) but not because the water burns.
    It may be that this reference was to the expansion rate of water to steam which is a very impressive 1700:1. This will give you some substantial energy release in the combustion chamber, but as soon as you get steam you're going to put out the fire producing the heat needed to make the steam in the first place.
    It does appear, however, that we may have strayed a wee bit from the original purpose of this post.
    Mar 2008
    Allegan, MI
    MikeinGA -
    Water will merely vaporize in the combustion chamber (or any other type of fire). It does not dissociate readily, so the oxygen and hydrogen cannot form gasses that can be used in combustion. Water is a stable chemical compound, that is very difficult to break into its component parts.
    HDXBones -
    The air density I am talking about is that measured on an air density gauge. Moderately humid air is denser by the meter. I know what you are saying, and I was trying to explain much the same thing. Basically there is less available air in humid air than in dry air, so there is less fuel required to maintain the same A/F ratio.
    -Scotty
    Aug 2007
    Greeneville, TN
    I can understand why this post has pretty much become a private discussion. To add to the muddy water, there really is more oxygen in humid air (by volume) than there is in dry air. But of course, Scotty is right (and problaby HDX has said this too but I didn't have it in me to read back through all the posts). The O2 in water, be it liquid or vapor, is just not available for combustion.
    The volume of H2O in the air displaces the O2 that is available for combustion thus lowering the actual, usable O2 in your fuel/air mix resulting in less power and thus, less MPG for the same volume of combustible mix in your cylinder.
    Wow! It almost sounds like I know what I'm talking about! Good enough to fool my wife anyway!
    Aug 2007
    Greeneville, TN
    .......now that we're up to speed on air density and the effects of altitude and humidity, who wants to discuss Bernoulli's principle and carburetor icing?.......
    Wow! And I thought I was getting a headache before!
    Since we are injected and not carbureted (Spyderwise that is) I think I can afford to skip this one...
    MOgang Member & Monster Member
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    WHEW!
    I just turn the key, hit "mode" and off I go. Glad you guys have all this figured out.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by SteveMac View Post
    WHEW!
    You are so much better off for it too!
