Replacing Torx fasteners with Dzus fasteners speeds up panel removal considerably. For most plastic panels, the 14 mm length is correct, but where thicker plastic is encountered, such as on the rear wheel splash panel, 16 mm Dzus are better. True, 14 mm can be used on the splash by bending the female clip, but it takes a while to get the bend just right, and, while panel removal is always quick, replacement can be hit-or-miss, sometimes quickly done, sometimes a bit of a struggle, as the reach of the male part is minimal. Using 16 mm Dzus solves this, but at a cost. They are listed as "special" Dzus at Kurveygirl.com, and at $6 each, are twice the cost of 14mm. Also, for some reason, Julie does not ship the 16mm's with a clip, which must be paid for separately at 75 cents each. Also, the 16's are only available in silver finish and only with D-ring heads.
Another place that 16 mm Dzus can be used to advantage is on the bottom plate that has to be removed during oil changes. I know lots of ryders simply remove this panel and leave it off, but I often ryde where there are fallen branches on the road and have had wiring snagged before. Thinking of my GPS wires, I decided to keep the bottom plate on.
When using 14mm Dzus on outside body panels, I like to use the black, button-head design. These are neater than D-rings and look very much like Torx. They are designed to remove panels with a quarter-turn of a T27 Torx screwdriver, but I prefer to use either a 5/32 inch or 4mm Allen key. These tools are small enough to slip in a pocket so you always have one with you.
I have been thinking about converting over to these fasterners so appreciate your insights. Would hope that future Spyders come out with these in place for all maintenance areas.
Neez
I purchased the Dzuz hardware you mention above and have found that I need to widen the notch in the body panel where the clips(female) slide on or attach, otherwise the clips do not slide deep enough into the panel. This is on a 08 RS. The panels are already notched for the factory clips but this notch is not wide enough for these Dzuz clips. Just wondering if there are different width clips?
NeezI purchased the Dzuz hardware you mention above and have found that I need to widen the notch in the body panel where the clips(female) slide on or attach, otherwise the clips do not slide deep enough into the panel. This is on a 08 RS. The panels are already notched for the factory clips but this notch is not wide enough for these Dzuz clips. Just wondering if there are different width clips?dzuz.jpg
There are no different width clips, Jesse. You will have to do a bit of minor surgery to the Spyder to widen some of the notches. I used a pair of diagonal pliers to nibble the plastic notches a bit wider or a Dremel grinder on metal notches. Often you can get away with just shifting the clip around a bit, say by dropping one side of the clip into the metal notch, sometimes this will bring the holes into line enough. Don't worry overmuch about the clip slipping off, as they grip tightly. I have never lost a clip off my Spyder yet or had one slip out of position once lined up.
I think this is a great idea. Has anyone actually made a list of what is required for the RTSM5 (AC)?
I go to the web site and it just makes my head hurt. Kinda like a Rubic cube for rivets.
Hopefully someone who's done this has a list of required/nice to have with #/type and length. Or maybe it's here and I can't find the list. Also, does Fastenal carry these? There is a big place in Woodstock, GA, down the road a piece and another in Cartersville. Don't know about their pricing either.
UPDATE: The post below is from Julie at KurveyGirl not from me. I'm just the messenger..... Sorry for the confusion!
Hi, we have not developed a Dzus kit for the Can-Am Spyder RT, or the RS and GS for that fact. - The RS and GS riders have been using the 14mm working length dzus bolts with sucess. - We would expect the same 14mm to work for the RT, but again we have not confirmed this application.
We are planning to develop kits for the Can-Am Spyder in the near future. Please check back with us in a few months to see what we might have come up wtih.
That is an excellent idea to replace those little plastic pins thanks for the info the Dzus fasteners are a much better mounting hardware for quick release panels now getting a kit specific for each modle would be great.
I used the D-Ring 14mm all the way around, and while I agree about the issues with the rear splashpan, its not a panel that requires unscheduled removal. I ride into D.C. everyday, and haven't had any issues with anyone messing with the bike. The ability to strip the all tupperware in under 2 minutes is priceless!
One issue I do have is that the plastic washers that hold the Dzus "captive" keep getting lost. I need to find a more permanent solution. Any ideas??
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
