Trouble starting my Spyder
I don't know if anyone else has/had this problem, but I can only start my bike in the neutral position. I took it to the dealer, and they said I wasn't stepping on the brake hard enough when it's in gear. I rode 120 miles yesterday and really pushed on the brake pedal while starting, and it still won't work. Start in neutral - works every time.
Why would you want to start in gear, I have a Polaris ATV that starts in gear and when i lend it out i warn them it starts in gear make sure your not on the throttle or when you start it it will take off on you.
Motorbike Professor
Could be a problem with the brake switch. Go back to your dealer and explain that it still doesn't work right. Stepping on the brake on a Spyder SE that has been parked in gear should allow it to start.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Thank you so much for that information. I will be contacting the dealer.
