Howling coming from rear wheel well
OK...so I've pinpointed where this weird sound is coming from. And it only happens after my Spyder has warmed up a bit. Then it's like clockwork. There is a definite "Howl"....almost a whine or a cry coming from my rear tire--and it seems like it's happening inside the wheel well (or casing or whatever you want to call it). I can literally drive in circles and every time the wheel passes through a certain part it makes that cry...almost like a rub...close to the sound a wine glass makes when you rub a finger around the top of it.
Anybody else had this? It's really bad when I'm braking, but it will make the sound without the brakes at low speeds. I'm about ready to take it in and have it looked at, but I'm not under warranty and I just know it's going to cost a fortune.
Any advice is appreciated. I was wanting to go on a nice ride this weekend and now I'm a little worried to.
Thanks,
--ABQ
HOwling
Just a thought, could your pads be dragging ? If take it for a short spin and manage not to brake ( I know hard to do) touch your rotor ( be careful) it may be hot ,if it is you are probably dragging your pads. Or jack up the frame and spin the rear wheel do you hear anything ? Every bit of info helps.
Can I use my SUV's jack for my Spyder or do I have to go buy an ATV/motorcycle jack?
A floor jack under the center of the fram will do it.
jacking the spyder
Floor jack w/a small block works great. But in a pinch the scizzor jack from your car will too. Make sure you block the wheels though, so it doesn't move.
Thanks. I'll try it. I just don't understand why it doesn't happen until it warms up for a little bit. Weird.
