12V Accessory Socket
I'm wanting to install a 12V socket somewhere in the front to run a gps. I'd like some ideas on where to mount and wire it in. Also where you purchased it. Thanks in advance.
Banged Up Member
See if any of these are applicable?
http://www.spyderlovers.com/forums/s...earchid=116641
Chris
Look here for where I placed mine http://www.spyderlovers.com/forums/s...added-thus-far I purchased the outlet at a local dealership
Be Safe
AC
2014 RT S SE-6 Cognac, 2014 Indian Chieftain. Retired Navy Chief
Power outlet mounting
I placed mine on the left hand speaker screen near the lower corner. Worked well. Easy to access and did not have to drill any holes in the tupperware. The speaker screen can be easily/cheaply replaced if necessary. Purchased the BRP outlets online. I believe I got them for $10 each including shipping.
Just the info I was looking for
Always forget the picture.
This shot gives you an idea.
Motorbike Professor
Originally Posted by MMcc
That's where mine are. too. Easy to remove the grills to drill the holes, and more room behind for the outlet and wiring than some other locations. I recommend the Powerlet (BMW-type) outlets. They hold the plug and maintain contact better than the cigarette style. You can obtain them directly from Powerlet, frome vendors like Eastern Beaver (if you also need a fuseblock or ready-made wiring), from the local BMW or other large bike shop, or from a variety of other vendors.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
