SpyderLovers Sponsor
Originally Posted by arntufun
I love your new wires and will be purchasing a set over the winter. Not that we do not trust you but I have to ask, is there a warranty on these wires ???
Warranties are a tricky thing. I'm not Wal-Mart so I can't afford to replace wires for any reason at all. I can't imagine someone having an issue with these unless, A) They really abused them or, B) There was some fault on my part in assembly. If the wires are faulty then I will make it right. If you have an issue with these wires let me know and we will go from there.
I think I am a pretty reasonable guy, but then everyone thinks that of themself and we know it isn't always true. I will do my best to make a customer happy.
Thanks Ron!
(Hoping that I'm one of the lucky ones... )
Me too!
IBA #47122
2020 RT Limited Asphalt Grey
Ron
I posted last week for a set of wires and spark plugs but I see
my post is now missing. Well don't know what happened there
but I still would like the wires and plugs. Did send a paypal payment
to you last week and have a receipt for that. Looking forward to
getting the wires when you catch up with the orders
Thanks Henry
Oh, have a 2010 RS SE5
Originally Posted by HenryA
Ron
Thanks Henry
If you've sent payment then you're at the head of the list. Once I start shipping tomorrow I'll notifiy those that have a set coming. If you don't hear from me then I haven't shipped yours yet. I'll get them out as soon as I can. I appreciate eveyone's patience. I'm looking forward to having these on the shelf so I can ship them out as soon as you order.
Take your time in making them. No mistakes.
The biggest mistake was in saying something before I had them ready. I've been surpised at how much I've had to put into this project. You'd think a set of simple spark plug wires would be a piece of cake!
Don't get discouraged Ron; We'll wait if we have to!
Years ago a very talented fellow developed a unique and very strong bumper for the Yamaha Grizzly 660s. (The stocker would twist up under a withering glance!)
I was lucky enough to get the 3rd one he made. He shut down production because it was so labor-intensive and folks were so impatient...
So hang in there and we appreciate your talented solution!
Nice rack!!!
Hey Ron -
I know you are busy with these wire sets and and all. It sounds like there may be a bit of a wait. I would like to order a set of wires and a set of plugs for Phantom 14 (2009 Phantom GS). When you are in a position to take more orders please let me know and we can proceed. May need some other stuff too but we can discuss that over email. Just wanted you to know that I am excited about your wire solution. Thanks man!
Thanks for an excelent job well done.
Will I be getting mine in the first batch, or the next one ?
IBA #47122
Wires are red and black everything else is a plus.
Got my wires today and craftsmanship is excellent. Way to go Ron!!! Just looking and feeling them they are head over heels better than stock.
I made them this way for the sole purpose of matching your Spyder! The shame is that you'll be covering them up with all the Tupperware. But they will work just as well even though you can't see them.
Today
Well, just went to the maibox and have received the ignition wires and plugs from Ron.
The product looks great, thanks , Ron.
Now.... if the 6" of snow would just GO AWAY........
Bill Pitman
Also impressed, thanks Ron. One question, how do you center the coil wire end in the boot to install or do I just wiggle it into place.
If you straighten out the coil boot, the wire will center itself in the boot. You can do this in your hand to see how it works. It doesn't have to be perfect, just close.
First, start the boot onto the coil. Once you have it on 1/4" or so, it is easy to straighten out the boot as you have leverage against the coil. Then slide the boot all the way onto the coil and you will feel and hear a slight 'Pop' as the terminal ends mate up. The terminal end is recessed quite a ways into the coil.
Here is a copy of the current instructions just in case;
Thank you very much for purchasing my Custom Ignition Wire Set. I’ve put a fair amount of research and energy into this project and I think you’ll find these wires to be some of the best you’ve ever owned.
From the Large Diameter, Low Impedance Spiral Wound Race Wire, to the High Quality Accel Silicone Boots, these are the highest quality components I could find. Not only will these wires deliver a stronger spark while reducing the load on your coil, they will far outlast OEM wires.
You do not need to remove the air box to change spark plugs but you may need to remove the top and loosen the lower portion of the air box to replace the front cylinder spark plug wire if it is zip tied to other components.
Spark Plugs
Do not use Anti-Seize or Dielectric on Spark Plug Threads! You Must Use Thermal Paste! Apply a THIN layer of White Thermal Paste to Spark Plug Threads (White Packet Supplied). Do not get Thermal Paste on the Spark Plug Electrodes.
Wire Installation Instructions
Installation of these wires is straight forward. It is best to replace l wire at a time. After removing 1 wire, route the new wire in the same way making sure there is no contact with the engine or other hot or sharp parts.
Apply a SMALL amount of Clear Dielectric Grease (supplied) to the inside of the Spark Plug Boot. DO NOT apply Dielectric to the Coil Boot!
Grasp the plug boot at the wire end. Be sure that the terminal seats properly over the spark plug connector.
Coil End Install
The only tricky part is the coil end. Because the Coil Boot has a 45 degree angle, the wire terminal end will lay against the side of the boot. This terminal end needs to be centered in the coil boot so that it will mate correctly with the Coil Terminal. This is easily accomplished by straightening out the Coil Boot as you install it. DO NOT apply Dielectric Grease to the Coil Boot!
Position the Coil Boot so that the bend is angled upwards towards the frame where the wire will be routed. Start the coil boot onto the coil, then straighten the coil boot centering the terminal end and slide the Boot onto the Coil as far as it will go. You should be able to feel the wire terminal slide on over the coil terminal.
If you have any questions orcomments, please email me at fyredad@hotmail.com or PM me (bajaron) onSpyderlovers.com web forum.
10-29-2011, 07:47 PM
#100
