Doc, these should do just fine in the new engineIMG_0351.jpg IMG_0352.jpg Chrome and Ceramic.....Not your normal everyday pistons, thats for sure.....Cant wait to hear her fire up.
And now, the question: what's the difference between a turbo and a naturally aspirated Rotaxengine piston melt down?
Doc,
The turbo pushes more air/gas mixture into the cylinder that will increase the pressure and causing more heat. Ever look into a water or water/alcohol mix mist in the intake, to help to cool the cylinder and piston.
Doc,
The turbo pushes more air/gas mixture into the cylinder that will increase the pressure and causing more heat. Ever look into a water or water/alcohol mix mist in the intake, to help to cool the cylinder and piston. Mike
It is included in the new fuel management. More info's: send pre-signed non-disclosure agreement (basically that you don't disclose that to BRP) ...
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
You might want to add Firefly to your speed-dial; I heard that he went to court on a "40 over" ticket once and ended up getting an apology from the Judge and a date with his daughter!
Oh I thought he just got a date with judge judy, given that Randy isnt seeing her anymore.
