XM-RADIO Handbook (help needed)
REAL HELP NEEDED:
hey Spyders who v'got the original OEM BRP XM-Radio installed at your RT???
I just can't figure out how to favorite some of my channels into the shortcut scroll list (white block bottom left).
There was no user guide given to me - just the installation procedures which tell me nottn about usage
- any help would be much appreciated!
Banged Up Member
See if the following helps. I've even tried what I'm sending you and still having problems.
http://www.spyderlovers.com/forums/s...t=badazzspydee
Chris
thanks Chris,
seems like that will do the normal AM/FM radio - but I'm looking for the XM Satellite Radio guide ...
Banged Up Member
I guess that's why I can't get my presets to work either. For my XM that is.
With Xm up on the camand center, hold down the set button untill you see a xm screen come up with station choices. Pick the catagory that you desire and right click to the different staion that you desire. After you pick one, say 60's press the right key again and it will switch back to the main xm screen. You will see a record indicator showing. Look at your preset number and use the arrows to change it to the desired preset and then push the down button to record the station to that preset. You can do this up to 15 presets. Hope this helps. Bob
