Tire pressure, handling & wear.
I just set my tires to BRP suggested pressures. (15/28). I want to know how the handling is affected with these numbers and how will the tires wear ? Is there a specific reason they give these numbers on the pull out card ? I know many of you use 18/28 and above. Are the factory numbers better for the tires and for handling or not ?
Gordon
Banged Up Member
I'm not sure I can completely answer all your questions. I can say that I kept 20 in the front tires, 28 in the rear and got 15,000 miles out of the rear and still have the fronts at 19,000 with plenty left on them. I have an RT-S, I ride moderately aggressive, 80 percent 1 up and 20 percent with passenger. 99 percent of my riding has been in FLARDA where it's mostly flat. Hope this helps.
Chris
Tire pressure , handling and wear !
Chris
I did have 20/28 and wanted to try lower settings. I had 17.5/28 yesterday and switched to 15/28 (BRP settings). The ride did seem very soft and smooth, but I just wanted to make sure the bike will handle properly at these settings and I will get good tire wear, or not.
Gordon
Motorbike Professor
Manufacturer's recomended tire pressures are a combination (and a compromise) between the sweet spots for comfortable ride, cornering traction, straight-away traction, tire contact (even wear), and the loaded vehicle weight. They may or may not be the safest pressures...remember the Ford Explorer fiasco? Like MSRP, they are merely recommendations. Finding your own preferred pressures is your option. How your Spyder rides and wears will differ from others, depending on your weight, cargo and passenger load, climate, the roads you ride, speed, and many other factors. This is something you are going to have to determine for yourself, with the manufacturer's recommendations and what others have used as a starting point.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I have my tires set front @ 28 rear @ 30 just for the reason if riding the RT I ride double ,If I ride solo I ride the two wheeler ...nancys toy I have a question I think My rear tire is showing some wear in center of tire are there wear guides on the tread??? How much tread shoud it get down to before thinking about replacing .Trike has over 80000 mIles on it now
Jack
Mistake on typing fronts are set at 18 PSI
Jack
Jack
There are wear guides, Look at the sidewalls you'll see little triangles that will be in line with the wear indicators, Don't confuse the higher blocks with 5 horizontal lines on them .
Those are water blockers, the real indicators are deep down. Your Manual will have a picture of the indicators and how to locate them.
Also the Spyders rear tire tends to wear at the center treads fairly quick.
