Originally Posted by LennyO
Could you please, elaborate on what you mean by this?
Was there another problem that made it run hotter? Thx!
First off Lamont I was not saying I know more than you and you are wrong and I am right, you defiantly know a whole lot more about the Spyder than I do I just know that my spyder began to run hotter after the update even on the highway riding at 80mph and with the ambient temperature in the low 60's I can feel the heat is hotter than before and my cluster always showed me 3 bars and now 5 with fan running all the time.
So after all these posting and Lamont's finding on the cluster/bars reading and temps this is what I believe might be my problem with my bike running hotter, I have the Evoluzione Spal fan controller that you set to turn on your fan first at 50% and then at 100% the way this is done is to use the cluster temp bars to set the fan so what I believe has happen is the update has somehow affected the way the bars now show up on the cluster and this might have changed how my fan controller come on and maybe has now made it come on later because it is now getting a false reading which of course makes it hotter but the Spal is getting a temperature reading from the factory sending unit also which I would think that is where the cluster is also getting the reading from as well I will have to look into this and change the setting to see if this helps .
So my new question is if the cluster temp bars shows more bars and climb much faster but engine is not running any hotter what's the purpose of the temps bars and where is this getting the reading from, does not seem that the temp bars are of any use if you can not rely on it to give you an accurate reading on your engine coolant/temperature and I still say that the cluster update has affected the running temperature of the spyder engine some how and maybe it's running hotter but the cluster bars are not really showing you the real reading or it's now not getting an accurate reading as well. I still want this update removed from my Spyder and I should have the choice do have this done.
I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
SAVE THE CHUPACABRA
If you have not been to Luckenbach, your journey is not complete.
Originally Posted by Mr Orange
I would disconnect the controller and see if things go back to normal.
If it is firmware then it won't be removable but what I don't understand through all this is WHY did you get the odometer update anyway if you knew you were never going to get that high on your millage???
I did connect the factory controller back and bars on cluster still went up fast and fan came on same at 5 bars but went to 6 bars a few time (never seen 6 bars in two years I have had my Spyder). I did not know what this update was till it was done and if I knew I would have not let them do it, I was there in the first place to have the belt tension checked.
I thought since it's BRP I should not have to worry if they will do something to my Spyder after all they are the manufacture and we should be able to trust them to properly test these things out, but guess what we can't.
Originally Posted by Lamonster
What can happen is when the throttle body plates are being held shut for 40 min. they can get stuck and burn up the motor and then you have to replace the throttle body. This fix is going to back it off a degree or so.
I was told by Kurt Otteson that there are actually two throttlebody problems. The first one is a defective hardware condition in which the butterfly valves get "sticky" and will not close properly (won't idle down). The second one is the firmware problem you describe. I have had the first problem twice and my throttlebody has been replaced. My 2011 RT is on it's third throttlebody. I will have the firmware update to prevent the second kind of problem which is much more serious.
Originally Posted by Dochands
Basic question. What is this cluster update for?
To allow it to count miles to 100k without update it will 0 out when it hit 100,000 kilometers
Happy Spyder Owner
I have been thinking about the perceived problem with the engine temperature. It seems we should now see six bars pretty much where we would have seen five bars. With this logic, are we going to see limp mode (seven bars, or so) when it is not necessary?
Motorbike Professor
I sincerely hope that this "update" doesn't get shoved down our throats, like the junk that was buried in the DPS recall update. It would be nice to have a choice, instead of having this automatically downloaded to our machines when BUDS was hooked up. Gee, you would have thought BRP's programmers would have learned their lessons the first time they buried extra code in a fix.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Alignment Specialist
Lamont,
Thank you for running that temperature check again...
I think I now know why my bike wasn't being affected by the missing air dam...perhaps the air dam is working fine and the bike is just reading hotter, when in actuality, it isn't?
Good work on your end...always appreciative from my end!
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
It is not automatically download.
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
Motorbike Professor
Thanks, Doru! That is a relief.
-Scotty
SpyderLovers Founder
Thanks for posting this information Lamont. I especially liked seeing your side by side comparison photos to show what the actual water temps are. Great job bro!
Originally Posted by Double Trouble
Visited with my dealer this morning. The update is for the 2011 model only. We checked the VIN on both my wife's '10 RT and my '11 and only the newer model requires the update.
Rick
So if the throttle body software update/fix is only for the 2011 RT does this mean 2010 RTs don't have the problem? I thought Lamont's RT is a 2010 and he is taking it in for the update/fix
Only the 2011 models are affected. Maybe his 2010 Spyder had a 2011 throttle body upgrade?
Lamont, is this the case?
The 2010 do not need or can use the upgrade because they still have the potential for the hot start issue. I may have had that problem a time or two in 30K+ but it hasn't been a real problem on my 2010. This is not something that can be retrofitted to the 2010 from what I understand and I'm not sure I would care to have it done if it could seeing this is not a big problem.
Shut up and Race!
Doc, do your data points correspond to bars 3, 4, 5, and 6?
4, 5 fan, 5 fan off, 4.
Shut up and Race!
All they did was change the way the cluster displays the temp information. So you may now have a 6th bar displaying when your may normally have 5. You fan controller is going to read from the same sensor that it was reading from before, there is no change in that data. So disconnecting the controllers isn't goign to do anything, thats not how it works. The only thing they did was change what bars display for certain temp readouts. Putting it simply, it's an eye candy change, it's a visual display change for the cluster nothing more. Your heat is a couse of something else, maybee your exhaust wrap is degrading?? If you want PM me and I'll give you a call if you want me to expain how these things work. More then happy to try to halp you out.
No such luck, had mine in for 12,000 mile service got it back and runs 5 bars all the time now and won't go lower. Never knew they where going to do a software update. So here we go again with the software junk being just thrown at us and not being informed about it, BRP GUINEA PIGS.
On the road again, still riding, Happy owner
So updating the odometer messes with the temp gauge. What kind of people work at BRP ???
Whats next, an 02 sensor update changing the shocks ???
Is there a way to just get the odometer update not these other files that BRP trys to sneak in without customers knowing ???
When buds is hooked to update i don't think there is any choice. I got used to the temp bars right away, no big deal for me.
