Stopping for gas
I went on a road trip to TN this past week, and was the only in the group. It seemed that the motorcycles would fill up quickly, and I'd still be waiting for the gas to fill up on my bike. Seems that I had to wait for the gas to pour down in the tank before refilling it so it wouldn't overfill and spill it. Is there some special way of filling your bike up without having to wait for so long for it to fill?
How many times did you have the problem your talking about?I fill mine up all the time with no problem.The pump at the stations I go to seem to pump fast like if it was a car filling up and it fills the spyder up rather quickly also.I guess the work I did was good because you made it back from your trip.Did you have any problems with .
2014 RT-S SE6 Pearl White
Grip Puppies, 12 volt power outlet, BRP comfort seat, Tri-Axis adjustable handlebars, BajaRons sway bar & links, Spyderpops Bump Skid w/Inlaid LED's & Stainless steel Kott grilles,SmoothSpyder belt tensioner,Carbon fiber dipped wind deflectors,Lamonster NBV highway brackets,Lamonster cat delete pipe,
Don't put the nozzle in too far or it will keep shutting off. Just put it in about an inch and it should fill a little faster for you.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Mine fills up fast for the first 5 or so gal, but the last half gal takes forever. Small tank and not so great mpg's I need that 1/2 gal.
Accidently overfilled my tank a while ago and my fuel gauge went bonkers. Anyone else? As I ran the tank down it returned to normal.
Black collar.
Here in Missouri, we have the black collars that capture fuel vapor when you put the nozzle in your tank. I always manually pull the black collar back and visually watch the fuel go into my tank. As soon as it starts to spit some drops of fuel back out. I stop putting in fuel and/or pull the trigger ever-so-slightly to slow the flow of fuel into the gas tank. I can get in a few more drops that way. I have never had a problem doing this. I have never overfilled.
Previous owner of a 2008 Spyder SM5.
Current owner of a 2007 Yamaha Royal Star Venture
Are your sure? I have three daughters.
haahhhahah, priceless.
but seriously I do the same , get about 5.3 in pretty easy.
Not sure if the inch thing will work in Jersey. I filled up there thursday and they have this rubber spring thing that needs compressed or it will not pump. Maybe it was just that particular station. It has to do with the gas vapors not venting to the atmosphere. They also pump it for you but this guy handed me the hose.
Happy Spyder Owner
ISCI Floorboards, Ebrake extension peg, Hand Brake, and hyway pegs, tjfisher2 passenger peg extension, BRP 23" Ultra Touring Windshied, Backrest, Fog Lights, 12volt accessory plug, NMN 4" handlebar risers, Auto Zone red LEDs, BRP Comfort seat, Evoluzione sway bar, powerbus, powerlets and air shock.
