Results 1 to 25 of 41
    Springfield, MO
    Default RT panels off and on- video
    I had to do a little work on Freds RT so I thought this might be a good time to shoot a video of what it takes to get them off and on.
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    I never noticed the little tabs on the bottom of the first panel you installed. I wonder if they're there & I just missed them (had both sides apart this past weekend), or if they were not on the 2010 model. There is no push pin on that same panel on the 2010.
    Good videos. Thanks!
    Springfield, MO
    Quote Originally Posted by MarkLawson View Post
    They are on my 2010 RT and there is a push pin there too. Maybe yours is special.
    Jan 2011
    Moorhead, MN
    That was very helpful Lamont. I wish the audio on the first video had been better but a picture is worth a thousand words.
    Springfield, MO
    Quote Originally Posted by Badazzspydee View Post
    I'm still getting use to this camera. I'll crank it up next time.
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    The panels come off, and I thought my dealer had a special elf that just got in under the tupperware and fixed things.
    Man do I know the panels come off ! Try and put some of the chrome stuff on without takeing panels off .
    Happy Owner
    Springfield, MO
    Quote Originally Posted by fastfraser View Post
    It's a lot of fun isn't it.
    Apr 2011
    Wollongong, NSW, Australia
    You da man!!!!
    I am going to have to pull most of the panels off to instal the CB and GPS and your vids have clarified a few things.
    The mirrors are like the Beemer ones on the 1150RT...good to know. It's still a heart stopper when you first hit that mirror to release it.
    Even when you have the diagrams and the service manual I guess you just follow the panel around and remove what is obviously holding it down.
    But the clips are good to know and the sequence is all important.
    Thanks a heap.
    Cheers
    Springfield, MO
    Quote Originally Posted by Vyperyder View Post
    You da man!!!!
    Thanks a heap.
    Cheers
    Glad to help. It's like anything, the first time you do it you're not sure if you're going to break something but after that it's no big deal, plus it wasn't my RT so what do I care.
    Jul 2010
    Pittsburgh, PA
    fun is putting all the panels on and finding ONE bolt left in the side trunk that bounced out into the hinge area... (that's where I put them to hold them when taking off the side panels...
    eeek!!!
    found one bolt .... had to take off the top two panels to get to the one bolt on the bottom side panel i forgot to put on ...
    Apr 2011
    Oakland, TN (West TN area)
    Quote Originally Posted by Lamonster View Post
    SInce I have removed my panels several times, my friends come to me for assistance. Popping those mirrors off of their , always scares the out of 'em. Of course I have to act like I broke 'em
    2010 RT , Custom air brushed
    May 2011
    Arlington, Texas
    Lamont,
    Just wanted to say thanks for all your great videos and tutorials. I'm not the most mechanically inclined person, but when I watch how easy you make it look I go from " I can do that.....?" to "I CAN DO THAT!" Keep up the great work that you do here and keep those videos coming! Some of us need the !
    May 2011
    Cantonment, FL
    Thanks for the vids Lamont. I will be installing the frunk power port and an air horn - may even tackle the trailer hitch, time will tell
    Be Safe
    AC
    Very Active Member Hawk's Avatar
    May 2011
    Dacula, GA
    This was right on time!! I was going to have the dealer install my nuvo 660 today. They called and said that the mount kit does not have all the wires that is needed to do the install. So I will be installing it myself tonight so I can use it for the trip to Maggie Valley tomorrow!!!! Thanks for this!!!!!
    Should Make This A STICKY!!!
    Jan 2011
    Windsor, CA
    Very helpful, but you make it look so simple.
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    You're absolutely right! (Mine is special!)
    May 2011
    St Joseph MO.
    thanks for the how too
    but i have a ? i just got my bike the 600 mile sevice and my left bottem panel is lose so i pulled it off it has 2 rubber gaskets that the pins go in
    should it have 3?
    what im trying to say theres 3 pins but my back pin theres no ruber there just a hole
    did the dealer lose it or ?
    the only reason i seen it was i read on the fourms here about people losing theres after a service so i checked and it was barlly hanging on
    srry i type like sh.. hands to dam bigg
    Jun 2010
    Wales, WI
    My biggest problem is getting the tabs on the front of the side panels in the right place. I was installing scuff guards yesterday and could not get the tabs to engage. Lamont, is there a trick to getting those side panels back on correctly, I do not want to lose one on the road.
    Springfield, MO
    Quote Originally Posted by packbuckbrew View Post
    I would cut them off, they don't have them on the 2011 now I'm told.
    Jun 2010
    Wales, WI
    So I am not putting them on wrong if the tabs are not engaged to anything?
    Springfield, MO
    I was told that the front tabs made it worst when they wern't locked in. I would remove them all together. I don't have any on mine and have yet to lose a panel.
    Jun 2010
    Wales, WI
    Thanks Lamont, I will also add some Velcro as you have suggested.
    Quote Originally Posted by Rattigan_Roger View Post
    Yes, there should be three rubber grommets.
    Tell your dealer to cement them in as per BRPs service bulletin 2010–0006
    Hi Roger,
    After a particularly rough week... (error codes, crossthreaded oil dipsticks and dead pocupinges ) I have also found that I've got a grommet missing on the left middle whatever panel. Do you have a part number for them? I know that the Y-gaskets in the exhaust sytem can be replaced with a Honda part; is there an equivalent Honda part for the grommets too?
    Thanks!
    Chattanooga TN
    I lost the left panel in May after a service visit to the dealer when they did not set the tabs properly. And, this was after I had mounted them with Velcro, so I sure wouldnt count on that!
    Fortunately, the dealer took responsibility and sent me a new cover.
    Now my covers on both sides are seriously attached to the RT with tethers made from pic-hanging wire ...
    Jun 2010
    Lake Charles, LA
    There us one part that you made look awfully easy, that I had quite a bit of trouble with.
    The two "prongs" that are held on the bottom edge of the top side panel gave me a lot of trouble - the front ones are bent at a wierd angle - the one on the right side was bent so much that I couldn't get it into the grommet when the rear one was in the grommet - the front one finally broke as I tried to bend it to go into the grommet - should they be bent?
    Any tricks to getting the prongs into the grommets (or were my prongs bent too much by the dealer when assembling?
    THX, Boyd
