Changing sparkplugs
Before i do work on my spider i generally check threads just incase and to refresh my memory and noticed not to much on here about changing spark-plugs so here is my attempt to make things a little easier for everyone before i get started i will let you know that my roadster is an RS model but the plugs are all the same for RT.
Tools: ratchet several different lengths of extensions, 5/8 spark-plug socket
Spark-plugs: stock plugs are NGK R DCPR9E OR You can use these NGKDCPR9EIX Which are the Iridium plugs these are what i used also don't forget to buy some heat sink paste for the spark-plug threads.
First remove the top side panels on both sides these are the panels where your knees would be. before i go any farther i should let you know i do not have that massive air-box on my spider i have the kewelmetal aircleaner so if you have that box some people can change the plugs without removing it but it is a lot easier if you do. So now i remove the old plugs apply paste to the threads and and install and replace the panels and your done. Now before i forget the plugs should be gapped at .oo7-.008mm or .028-.031 inches i went with .030. BRP recommends changing them at 12,000 miles i did mine at 9,200. As i mentioned before i went with the iridium plugs on the recommendation of others and yes i could tell a difference and i am happy with them. if anybody has anything to add especially for the RT people please feel free to add on. and if i for got anything please correct me.
Roger
I can't emphasize this enough; When pulling the spark plug wires off'
BE VERY CAREFUL, They are easily damaged, And sometimes the damage won't show up right away.
Motorbike Professor
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
SpyderLovers Founder
Not having that airbox to deal with on the front plug is a big plus. If you do be ready for
The only thing I would add other than that is you can run the 8's and they seem to do better on the RT and are less likely to foul.
I'm getting ready to do the first oil change on my RS-SM and the dealer sold me a set of plugs, along with oil filter, seals, and synthetic oil. I have yet to pick up a service manual, but do the plugs require changing at the 600 mile service?
Nope. Leave them in. You should get several thousand if not much more out of them...
Unless you are me... then you seem to go through them every 3k...
WackyDan - Fun, not crazy.
Charlotte (Matthews), NC
Silver Moon SM5 - V35 and V46 Givis, CHAD, Motolight 35w steering lights, Dash Powerlets, Helibar risers, Garage door opener, Eastern Beaver PC-8, Digital voltmeter, Kewl Metal Intake, Evoluzione Sway Bar, RT Shocks and Juice Box PRO.
*Mower deck in development*
2008 model -new in crate, April 09
26,000 miles.
Looking for other Charlotte area riders to cruise with and compare Spyders.
HAPPY SPYDER OWNER
NA. The plugs should be good for 12 thousand miles, But I'll say one thing if you do change them at 6 hundred miles ,
You won't want to go though that again till another 12 thousand miles.
Thanks! Pictures are worth thousands of words!
Sea Doo GTI-SE 90 Jet Ski!!
Originally Posted by robo
My RS has done 26,700 k's (over 17,000 miles) so I thought it was time to change the plugs even though it was still running fine.
Getting the big air box out is a real pain,
After taking the top off the air box I found six screws that had to come out and most of them are hard to get at under the bikes top frame,
The six screws out and a couple of hose's disconnected and I wiggled it out
Room to get to both plugs now with the air box out of the way,
The plugs I took out still looked good, but in with the new ones and I won't have to do this job again for some time.
hey did u clean out the throttle bodies as they look really clean and good pics
No I did not touch them.
Is it worth using die-electric grease when refitting the leads onto the plugs for ease of removal next time?
The best substitute for brains & knowledge is....................silence.
YES. Also helps keep moisture out of that boot.
26,000 miles.
HAPPY SPYDER OWNER
RT-S PE#0031
Thanks for the pics. I'll have to save this post in my maintfolder for future references...
Mark & Mary Lou Lawson
Snellville, GA USA
'10 RT-S PE #0031
'10 RT-622 Trailer
'08 Yellow SM5 #2332
'01 Black GL1800A Goldwing #0930
"Remember in the darkness what you have learned in the light." - Joe Bayly
Well, I gave Spyder a service today after the big trip: spark plugs (with heatsink paste applied to threads and die-electric grease to boots), oil &filter, fuel filter, grease front suspension (quicker &easier to remove frunk than I thought), new front tyres, original drive pulley and new belt (see 30 tooth thread) adjusted parkbrake lever on spline at rear wheel. All good now and ready for the next big trip - but that'll be a while.
I'd previously fitted 8mm head bolts to airbox mount to aide in ease of removal/install.
Mark i sometimes do this myself copy paste and save for future references this is a good practice for everyone.
Roger
Anyone have difficulty taking out the spark plugs. Couldn't get a standard 5/8 socket into the plug hole. Bought a thin walled 5/8 socket but it wouldn't grab onto plug . Any ideals. Dirt or rust in the spark plug hole?
Thinking about trying out the new Brisk iridium plugs. Any comments?
Sent from my SGH-I337M using Tapatalk
Reason: mistake
Bought a second thin walled 5/8 socket
Bought a second thin wall 5/8 socket and it worked. Everything is AOK. Thanks
Biggest tip I can give about changing plugs...
The front plug hole catches a lot of dirt and rocks!
Blow out the area around the plug before removing the plug.
If you don't your engine will not like all that down in the cylinder!
Bob
2011 RT-S SM5 - Black
Hmm okay the pictures are there but all fuzzed out. How do I clear them up?
Get the poster to pay Photobucket regularly.
