Page 1 of 2 12 LastLast
Results 1 to 25 of 43
    SpyderLovers Sponsor SPYDERPOPS's Avatar
    Oct 2007
    Pearcy, AR
    Default Simple Heat Solution
    SPYDERPOPSDOES IT AGAIN!
    Eliminate the hot foot issues with your RT.
    If you want to rest your foot on your new highway
    pegs and find it very uncomfortable due to the heat
    coming from the radiator the solution is here. We
    installed dozens of the block off plates at Spyderfest
    with great results. This is the idea that Lamonster wrote up
    not long ago on the forum.
    Beat the Heat today at www.spyderpops.com
    Oct 2007
    Pearcy, AR
    Here's a picture of the "La Bloc" installed. Go to
    www.spyderpops.com and get yours today.
    Oct 2007
    Pearcy, AR
    This is how the "La Bloc" (named after the designer) looks before it is installed. It is black polycarbonate with heat shield material laminated to the back.
    Installation is very simple and comes with a special screw and clip
    to hold it into place. After it is installed you will only have to remove
    the lower body pan to help get rid of the hot air.
    www.spyderpops.com
    Registered Users wa3wheels's Avatar
    Aug 2007
    Federal Way,Wa.
    Default Heat sheild works as advertised
    I had this installed at Spyderfest and I am still on the road from Seattle,Wa. Area to Cuba,to St.Lewis did the Arch and Bud beer,then on to Knoxville,en n to Ashville for Bikefest. Next top the Blue Ridge Parkway, Deals Gap and surrounding area rides. Then on to Concord,NC for a couple of days,then on to Myrtle Beach,SC and followed Hwy.17 south to St.Augustine,Fl. And headed west to my current location of Gulfport,Ms. Then continuing West to interesting locations. This heat shield has been a ankle saver in the 90+ Temps that I have been traveling. Works as advertised and YES I would buy this item as with the Belt Guard again. Hope to see some that I met in Cuba at Spyders in the Redwoods. ( Ticketbait )
    wa3wheels How can u drop a raw egg onto a concrete floor without cracking it? *Any way you want, concrete floors are very hard to crack.
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    wa3wheels, you are absolutely right, this is an ankle saver, I had yet to try it in high temps but know with all the traveling around the country you and John have been doing , that is awesome to know it is still working for you
    Ray :PS ,really enjoy the email and photos you have been sending. ride safe
    LaBlock was installed in 5 minutes by Harvey
    Below is a photo of my bike with Ray's(wa3wheels) right behind.
    Aug 2007
    Springfield, MO
    I got to test this mod to the max on the way home. While driving through the desert I had constant temps of 104 to 107 for hundreds of miles. My temp never got over 5 bars and while stuck if traffic I had temps of 111
    I can say without this mod it would have been a real bummer trying to use my highway pegs. This works great and I'm glad to see Harvey offering it here.
    Very Active Member stevedfive's Avatar
    Aug 2010
    Riverside, California
    Before I remove the right side skid pan, what is it designed to protect or will there be anything exposed that could cause a warranty issue later?
    2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
    Oct 2007
    Pearcy, AR
    The only thing exposed will be more plastic. Some have taken a large hole saw and ventilated the air duct even more. I heard that one guy used a saws all to get more air out the bottom.
    Water won't be a problem as it flows through most of the roadster anyway, if you really ride it.
    Aug 2010
    Thank you
    Registered Users Havasu Rider's Avatar
    Aug 2010
    Casa Grande, AZ.
    Got mine at Spyderfest and it works great so far. It has already been over 100 degrees her and the temp. is the same before I installed it.
    Aug 2007
    Springfield, MO
    Quote Originally Posted by stevedfive View Post
    The pans on both sides are not there to protect anything, they are there so they could pass the noise requirements.
    MOgang Member & Monster Member
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    Heading to Florida Panhandle in July. Sounds like a must have item to me...!
    Very Active Member freebob's Avatar
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Trying to order your Item SPY111 on your site,,,Site not responding....
    Freebob...
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    I just ordererd belt guard and heat shield for RT.
    Thanks!
    Quote Originally Posted by freebob View Post
    Freebob...
    Apr 2011
    Midland, TX
    Does anyone have instructions or guidance on removing the skid plate?
    Monty & Shirley
    We love our . 2011 RT-S 991 SM5 Orbital Blue with the matching RT-622 Trailer, HMT Stoplight, fendertip LEDs, TricLed fender LEDS, front & rear Brightsides, Garmin GPS on the KewlMetal Bracket, Stebel Nautilus Horn and the Utopia Backrest. Corbin Passenger Armrests and SpyderPops Radiator Plate and Cat Shields. Ram driver and passenger cupholders. GT Racing Stripes.
    Mod Monster Phil's Avatar
    Nov 2010
    Tyler, Texas
    Quote Originally Posted by Wingman View Post
    My question too.
    Sent from my iPhone7 using Tapatalk
    ____________________________
    Phil - Tyler Texas
    2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
    Mar 2011
    Mcleansboro Illinois
    Default spyderpops
    I just want to add, Harvey installed a belt guard, heat shield and catillitic guards for me at Spyderfest. Mine was in the back of the line in ticketbait's picture. I love the results.
    A big hello to Ray/John,and Ticketbait all super people.
    Aug 2010
    I am having trouble removing it also. I got the two bolts from the center off. I removed the upper and lowers front side panels and then unscrewed the lower bolt to the skid pan, but it wont come out. Is there some type of retaining clip or something?
    Oct 2007
    Pearcy, AR
    Yes there is an assembly clip on the bolt if it has never been removed. It is there to hold part of it together going down the assembly line. I took A screwdriver and twisted it to hold the clip while turning the bolt. When the customer didn't care to keep the panel I would cut it at the tab and then tighten it back up.
    Aug 2010
    Thanks, I will look for it.
    Oct 2007
    Pearcy, AR
    I must add that it is very thin and is usually between the nut and radiator support. I have also taken needle nose pliers and twisted it to remove as it is brittle.
    Registered Users taggtr's Avatar
    May 2010
    Tucson, AZ
    Ordered my heat shield today. Gonna start being in the 100's here in Tucson starting this weekend and this mod will definitely make riding in the heat more bearable on the right foot! Can't wait!
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    Harvey,
    I ride with my highway brackets and pegs situated right at the lower opening on that side. I am looking for something to block that opening rather than the top. My assumption is that if I block the upper opening, it'll increase the airflow out the bottom opening and cause me more discomfort. Would that assumption be correct?
    Any thoughts on a product for the bottom opening?
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    May 2011
    Trinity, Florida
    Default Hot foot with RS SE5
    Quote Originally Posted by REPOPS View Post
    Would this work on my 2009 RS SE5?
    Oct 2007
    Pearcy, AR
    Quote Originally Posted by MarkLawson View Post
    Harvey,
    I'm looking into it, can you pm me a picture of the HWY peg so I can see where if is located?
