View Poll Results: If you had a fender break, do you have side bags on your spyder?
Voters
21. You may not vote on this poll
  • Yes
    9 42.86%
  • No
    12 57.14%
Multiple Choice Poll.
Results 1 to 21 of 21
    May 2010
    Knob Noster, MO.
    Default For those that had a Fender break
    Reading a post about the rear fender breaking, and got me to thinking. For those that had a rear fender break, do you you have bags or not? For those that have/had multiple Spyders, you can vote more than once.
    Yes
    No
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Invalid Emails
    Aug 2007
    Spring, Texas
    Havent had the crack, but have the Givi V35 bags on I7 Rack. 24000 miles on the odo.
    Registered Users Heliplt's Avatar
    Apr 2011
    Hood Canal WA
    Not back fender, while leaving the dealership my left front fender de bonded from mounting frame
    Absorb what is useful, use no limitation as limitation
    Doru the Destroyer-Spyder Photo Investigator docdoru's Avatar
    May 2008
    Clearwater, FL
    First break without, next 3 breaks with Corbins.
    2013 "Silver Dream" GG Taurus
    2008 "Silver Dream" Spyder RS
    Einstein's theory of drag racing: Time and Speed are Relative.
    Shut up and Race!
    Registered Users Erags's Avatar
    May 2010
    Milton, FL
    Default left side broke
    left side broke while on trip will see if BRP will cover when we get home2011-08-09 and 08-10 Andrews AFB & Wash. DC 0601.jpg2011-08-09 and 08-10 Andrews AFB & Wash. DC 0621.jpg
    Alignment Specialist bone crusher's Avatar
    Aug 2008
    MD
    Just curious about this question as the bags do not place any stress on any of the fenders...
    Bone Crusher
    If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
    May 2010
    Knob Noster, MO.
    Quote Originally Posted by bone crusher View Post
    I am thinking about getting some bags in the future, but did not know that about not putting stress on the fenders. Learned something new today
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    Dec 2008
    Syracuse, NY
    Isn't he talking about the fender brackets? It seems that any weight back there, from bags, a passenger, or yourself will stress the brackets anytime you hit a bump.
    Do you remember that post where it mentioned there was a bulletin dealing with the brackets breaking on the earlier GS's? The bulletin mentioned a specific torque sequence to follow; but, the actual torque value did not change. Supposedly, if you followed the new torque sequence, there would be less stress on the brackets when going over bumps, rough roads, etc. At least that's what I understood my dealer was telling me after he looked up the bulletin.
    Apr 2009
    Mission BC Canada
    I noticed marks on the fender brackets where they were coming into contact with parts of my Ind 7 rack. Modified the rack a bit which reduced, but did not eliminate, this tendency. When marks to the fender paintwork appeared and other people started to experience breakages, I eliminated the fender and brackets altogether. Now, my Givi side bags and topcase mount do the work of fenders. My passenger stays dry. The bad news is more road dirt on the insides of the bags; the good news is it is easier to get in to clean and for maintenance, and the side bags are easily removed for cleaning. I much prefer this setup.
    Very Active Member hawkiii's Avatar
    Apr 2008
    Northern California
    If you have the I7 rack with the GIVI bags and you develope the cracks, BRP & your dealer will tell you it is the fault of the non-OEM
    rack hitting the rear fender and you will pay for replacement yourself rather than have them replaced under warranty. Ask me how I know.
    Very Happy Spyder Guy
    The 2015 F3 has over 46,000 miles
    Have Spyder...Will Travel
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by wyliec View Post
    Since the swingarm is completely independent of the main frame I can't see how additional weight on the rear is going to put any stress on the fender brackets.
    Apr 2009
    Mission BC Canada
    The problem is actual contact with aftermarket luggage rack parts. This will occur if the rear shock is adjusted too soft, or if you hit a pothole. And yes, extra weight, of say, a passenger or luggage, will make it worse. Check the photo to see some contact marks. Later, several other indications showed up on both the fender and the brackets. If this continues, the fender will self-destruct.
    Aug 2008
    MD
    I thought the bulletin had to do with reducing the 'torque' of the 4 bolts...nothing to do with anything putting pressure back there?
    Bone Crusher
    Aug 2008
    MD
    Quote Originally Posted by hawkiii View Post
    Whoops...that stinks...I have the BRP bags and racks...nothing hitting, obviously. From what I've read here, the rear fender seems fragile, regardless...
    Bone Crusher
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Neez View Post
    Ok, I understand physical contact and that extra weight could be a factor if bottoming the suspension causes additional contact. I read that post as simply a weight factor alone.
    But it is my understanding that people are losing fender brackets with no contact issues.
    Invalid Emails
    May 2009
    Clearwater Florida and Frankin NC
    Doc went thru quite a few of them, but I think his TURBO caused them to crack.
    Aug 2008
    MD
    Quote Originally Posted by dave01 View Post
    Doc went thru white a few of them, but I think his TURBO caused them to crack.
    Apparently his turbo caused a lot more than just a fender crack!
    Bone Crusher
    Aug 2007
    Greeneville, TN
    My suspicion is that something was seriously cracked before anything on Doc's Spyder failed!
    Feb 2009
    Chiang Mai, Thailand
    My understanding why the stock fender brackets crack/split is because when you attach the fender you have to push in on both side to bolt on the fender and we all know how the back fender vibrates/shakes on the spyders and the stress I guess is what make them split.
    I also agree with Mr Orange the VTC fender look better as well, one solid piece don't know about any other bags but the corbin bags does not touch as the brackets don't use any of the fender holes for attachment.
    Dec 2008
    Syracuse, NY
    Are you saying there's no movement of the swingarm as you are riding down the road? That almost seems impossible; but, if you say so, I'll believe you.
    I'm not home today to check, but aren't the fender brackets attached to the swingarm? It just seems to me that any swing arm movement would transmit to the brackets.
    Aug 2008
    MD
    Now now...okay, that's too funny to ignore!
    Bone Crusher
