The Power of SPYDERLOVERS.com
See my forum the power of spyderlovers in general
Left turn switch Sucks dealer won't replace
My right turn switch works great but my left turn only works when I jam the switch on. I took it into the dealer (SK in Portland Or) they said they were aware of the problem but the new switches did the same thing.
I too have this problem with trying to cancel my turn signals, have started to use hand signals instead of the turn signal switch. A real PITA for sure. BRP are you listening?
I too have this problem with trying to cancel my turn signals, have started to use hand signals instead of the turn signal switch. A real PITS for sure. BRP are you listening?
BRP Quick Fix
If BRP is listening, here’s simple idea for a fix that will cost them and the dealers virtually nothing. Reprogram the bike’s software as follows: If either turn signal is on, then pushing the switch again in any direction (off, L or R) will turn the currently flashing signal off. End of problem. For the rare event when the rider might actually want to go directly from flashing L to flashing R or vice versa, just push it a total of twice in the proper direction (first time turns it off, second time turns it on in the new direction). End of problem. No concentration required, no staring at the dash to see if it’s off, no distraction from everything you should be watching at an intersection. My 2011 RT-S has this problem and it’s very annoying and not best for safety. Scotty’s idea works well but you still have to concentrate on it and still watch the indicators instead of watching for traffic and road hazards as you exit the intersection or finish changing lanes. Even my bright LED’s on my mirrors require a diversion of attention from the road. And at least one flash always occurs in the wrong direction before they shut off. Not good.
RT and Gold Wing States & Provinces
Just another whiner... thought that the TS on the RT was normal for Spyders until SWMBO got her 2008 GS. The turn signal button on the GS works like a dream. So, BRP apparently changed something on the RTs and most definitely NOT for the good.
Originally Posted by GadgetGuy442
Seems kinda silly that the technical challenges to engineer a properly and eloquently functioning turn signal switch are so elusive to BRP, yet they seem to do pretty well with VSS / ABS / TC and all the myriad of other highly complicated systems in the Spyder......
Bosch were responsible for the dumb electronic stability stuff.
Barney Rubble was consulted for the really intricate turn switch design.
Could have been worse but Fred was away on a brontosaurus hunt that day.
My signal switch has gotten really bad, it turns on just fine to the right. But to the left I have to Jam it to get it to turn on and sometimes it doesn't go on. I haven't had any trouble with it self canceling, but when I cancel a right a turn it turns on the left signal.
Dealer says it's not a problem!! Not his problem, it's mine.
If you can't hold his feet to the fire, I'd suggest that you contact Carlo. This is a safety issue.
Had a service manager tell me just yesterday it was my fault. He said he has only had one person in that had the problem and that I was probably making sweeping turns as opposed to 45 degree turns. He claims it is working correctly.
Your dealer is most likely correct.
As an engineer, I am embarassed to admit that functioning properly according to the design does NOT mean there won't be issues.
In other words, the turn signals operate exactly as designed, and the design sucks.
I'd be interested to find out if there is a fix for 2012.
IBA #47122
2020 RT Limited Asphalt Grey
My dealer asked me if I was having trouble with my switch. When I told him I was he said I wasn't the only one. I was told when BRP comes up with a solution he will let me know. As long as they don't stop working I'll wait & .
I filed a complaint with the NHTSA on Oct 13, 2011. The ODI number is 10429271 & can be found at http://www-odi.nhtsa.dot.gov/complai...e&refurl=email I filed it against both the lighting and electrical systems, so there are two complaints.
The Summary states:
WHEN ATTEMPTING TO CANCEL TURN SIGNALS (LEFT OR RIGHT), IT IS VERY LIKELY THAT THE OPPOSITE TURN SIGNAL WILL BE ACTIVATED RATHER THAN CANCELING. THIS CAUSES THE DRIVER TO HAVE TO CHECK THE DASH FOR TURN SIGNAL CANCELLATION. IT IS COMMON TO HAVE THIS OCCUR MULTIPLE TIMES WITH EACH CANCELLATION ATTEMPT, CAUSING THE TURN SIGNALS TO ALTERNATE LEFT & THEN RIGHT MULTIPLE TIMES ALL WHILE TRYING TO CANCEL IT. SEVERAL ATTEMPTS AND SEVERAL SECONDS OF THE DRIVER'S ATTENTION IS OFTEN REQUIRED TO SUCCESSFULLY CANCEL TURN SIGNALS. THIS PRESENTS A SAFETY HAZARD AS THE DRIVER IS NOT WATCHING THE ROAD AND TRAFFIC AND ALSO BECAUSE THE DRIVER IS SENDING CONFUSING SIGNALS OF HIS/HER INTENT TO OTHER DRIVERS. THIS PROBLEM HAPPENS AT ANY SPEED OR WHILE STOPPED. THIS PROBLEM CAN OCCUR WITH EVERY ATTEMPT TO CANCEL THE TURN SIGNAL. THIS PROBLEM SEEMS TO BE WORSE WHILE WEARING GLOVES.
Originally Posted by MarkLawson
The Summary states:
WHEN ATTEMPTING TO CANCEL TURN SIGNALS...
The problem is very accurately put. The date of your complaint is recent. What is your expectation of what happens next and how long will it take?
My expectations? Probably nothing. I hope someone who can effect a change will decide to fix it.
By the way, thinking back on first occurrence, I'm probably off a week. I think I purchased it one week later.
Originally Posted by fishcraz
Make that another 2011 RT-Limited with the turn switch issue....push to cancel and it turns on the other signal. Just put a 3 postion flip switch, push right it turns on the right signal, push back to center all off, and to the left left signal on. Simple 3 position switch...forget all this fance stuff...make it functional....please!
And I know it is suppose to self cancel...but sometimes the turn is not sharp enough to engage the automatic cancel when you straighten the handle bars back out. And then you look like a clown trying to get the signals off....not to mention it is confusing to other drivers and a danger.
My 2011 RT has the same problem,called my dealer and they said even there demo is doing the same thing.They are going to replace the switch.
Turn Signal
I had my turn switch changed on my 2011 RT Limited in november for sticking to the rt.
What I found even with the new sw was that is I just pressed the sw the blinker would not always turn off.
Then someone on this sight said to hold the sw for one second and it would return to center.
It does return to center when using rt or left. also shuts off after 20 sec. when moving.
I hope this will help.
Turn Signal Switch
My RTL is a 2011 with 3,000 miles on it and I have been waiting for a replacement for over 4 months with a promise of delivery by the end of Jan 2013. Which is not aceptable but what can you do ? Nothing but wait.
My switch won't cycle the lights on for a left turn and what makes it frustrating is it is an intermediate condition sometimes it do sometimes it don't. Around here with all the crazy drivers around this area you need a working turn signal switch.
Design defect
Money talks. Has anyone considered consulting with a products liability attorney? This has all the earmarks of class action lawsuit. It's probably imprudent to wait for someone to die as a result of the turn signal defect before taking legal action to force BRP to take corrective action.
If you don't ask, you don't get
BRP is NOT a publicly traded company, leaving few options to apply leverage to the company to take action. In the US the NHTSA regulates motor vehicle recalls. THe agency's website states:
NHTSA conducts defect investigations and administers safety recalls to support its mission to improve safety on our nation's highways. NHTSA is authorized to order manufacturers to recall and repair vehicles or items of motor vehicle equipment when investigations indicate they contain serious safety defects in their design, construction, or performance. NHTSA also monitors the adequacy of manufacturers' recall campaigns. Before initiating an investigation, NHTSA carefully reviews the body of consumer complaints and other available data to determine whether a defect trend may exist. [emphasis added] The interpretation is that the agency is more likely to take action if they receive alot of complaints about the same issue. I believe that if everyone on this thread filed a complaint with the NHTSA there's a good chance there would be a recall and everyone's turn signals would be replaced; at least that's my hope. If you are interested in filing a consumer complaint with the NHTSA, the link is below. I filed mine today.
https://www-odi.nhtsa.dot.gov/ivoq/index.cfm
