Do all SPYDERS squeal when you give them gas?
My Spyder always squeals when I am accelerating. Only at minimal throttle does the sound die down to less irritating noise like in 5th at cruising speeds. It's so loud that my friends who were following me with their windows up heard it and asked me why the thing squeaky squeals all the time so loudly.
I get the impression this is not normal. When I search for it on forums I normally only find posts associated with brake squeal. I don't have that; my brakes make sort of clicking sounds.
Is this a belt issue?
If its more like a howling or whining sound it's probably the belt, Too tight, or most likely the belt rubbing against the flange on the rear sprocket.
Almost 3 years now and i can't completely eliminate it,
And believe me i've tried.
Blazing Member
40k on my SE5 and never herd it squeal before. There was that one time I smoked the tire and it squealed and it sometimes squeals in reverse but that's just the brake.
MOgang Member
Same here, I would have a shop look at it soon.
I guess its sounds like rotational chirping that is proportional to the amount of throttle I give it. It's loud, annoying, and makes the thing sound like it's struggling instead like a motorcycle engine that could.
I'll take it in again, but I don't understand why it wasn't caught by the dealership as it's been present from the beginning and they had the thing in there more than once.
Their are good dealerships and then their are bad ones, luck of the draw...
Any resolve on noise
Jon,
I am having exactly the same issue, thought is was belt but maybe not. Sounds like its coming from the left front tire, like you said a chirping sound but only on acceleration, let off the throttle it stops.
Did you find out what it was??
Thanks,
Dee
Demand to have the belt properly retensioned and aligned as it wasn't done right
Originally Posted by Spydee1
Hey Jon,
I posted on the forum but just in case you did not see it I wanted to ask you if you determined what was causing the noise you described when accelerating. I have a new 2011 RT-S that is doing the exact same thing and I will probably have to take it to the shop.
Any info is greatly appreciate.
Dee
Sorry Dee, I must have not gotten the thread update. I had to take it back 3 times and demand to have it resolved. I guess they don't care to take the back wheel off and redo the alignment and tension of the belt if they measure it to be in spec. The last time I took it in I was there to get the bouncing analog fuel gauge fixed and employed them to please take another look and resolve the squeaking. It is not normal. The belt causes it when it is loose and/or misaligned. (unless it is only during breaking than its likely the brakes) Have them drive the thing and have one listen outside when the person applies the throttle. Sometimes the mechanic doesn't notice how loud and annoying it is, but people around you will definatley notice that its not normal. When he took mine out the service manager and the general manager heard it loud and clear. Chirp Chirp Chirp in concert with throttling. They took the back wheel off, adjusted the belt properly and as of last weekend the issue is resolved.
The last 2 attempts helped, but it wasn't fixed. Just bring it back to them the minute it does it even after they claim to have fixed it, if you still hear it chirping.
Someone is not assembling the bike properly, not adjusting the belt tension and alignment properly and then ignoring the issue after the sale.
Senile Member
Depending on the humidity, mine squeeks a bit (at rear wheel belt and flange area) when rolling backwards.
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
Thanks Jon,
I guess we will take it in tomorrow. I was hoping it was something simple since the dealer is a couple of hours away and we will have to rent a trailer. My husband actually put the bike up on a jack and revived the engine, no sound whatsoever. Also tried it in reverse on the road, again nothing. Its only with forward movement while accelerating.
Again, thanks for sharing your experience.
Dee
update
Hey Jon,
You nailed it, I really did not think it was the belt but hubby did. He had what seemed to me a strange idea to prove or disprove the belt theory. He took a candle and with the bike on a jack again, I turned the back tire while he rubbed the candlestick along the belt. Took a test dive and guess what, no noise. So off to get belt adjusted.
Just thought you might want a follow-up.
Thanks again,
Dee
SpyderLovers Founder
Had a new tire and belt adjusted this week and guess what? I have a squeal that sounds like it's coming from the front of the Spyder. Now that I'm reading this post I know it has to be the belt because even though I did have the front tires changed it is in harmony with the throttle. My guess is my belt is too tight. I should have checked it myself.
Squeal
Mine did that from day one and at the 600 mile check, that was one item on my list to be addressed. It turned out to be belt tension and rubbing against some guard gizmo down there that the belt chewed up. Don't know any more about it other than the noise is gone. So, belt alignment?
Patrick
2011 RTS 2006 Yamaha Morphous
2017 F150 2015 MINI Cooper S IBA 56167
I guess that I'm gonna have to turn my radio down for a listen...
In all seriousness; The belt on mine started out pretty far over to the left, but this Spring it has come back right so that it's currently centered ... Should I be worried about its trip across the cogs? Will it continue right until it hits the flange??
I would wait until you hear the death squeak
Patrick
This is what I thought all along
I tried to get the issue resolved at the 600mile service, but they were busy and other than spraying something somewhere don't think they took the time to nip it in the bud.
Spyder Throttle Cry
After 120K miles, 6 front sprockets, 2 rear hubs, 4 complete sets rear bearings, 2 rear swing arms, 2 belts...your problem is rear sprocket being out of alignment.
Thanks everyone, I have learned a lot from this post.
Doc, can I ask you a question. If it is indeed the sprocket, would putting wax on the belt temporary resolve the issue. Before, it made the noise all the time, not just now and again. But after waxing the belt, it stopped immediately.
Thanks again everyone.
Dee
Doc, can I ask you a question. If it is indeed the sprocket, would putting wax on the belt temporary resolve the issue. Before, it made the noise all the time, not just now and again. But after waxing the belt, it stopped immediately.Dee
In time will destroy the bearings, seals and belt. The rear tire should have excessive wear.Have a good mechanic remove the rear wheel, inspect the hub, seals and bearings and re-install and align the sprocket/wheel/belt correctly.
Docs doesn't squeal, it cries from the pain of full acceleration.
Sent from my DROIDX using Tapatalk
