Page 3 of 3 FirstFirst 123
Results 51 to 74 of 74
  1. #51
    Registered Users Rando's Avatar
    Sep 2007
    Mesa, AZ
    Default It's back home!
    My Spyder RT Limited is back in the Spyder Den, now I just need some nice weather!
    This was an expensive lesson for the dealership. The wiring harness alone was $246.93 so with the labor and additional part, the paperwork they gave me a copy of showed a total of $501.68!
  2. #52
    Sep 2007
    Mesa, AZ
    Spydie still no workie! Anyone know if Michigan has a lemon law that covers motorcycles?
    It worked when they loaded and unloaded it from the trailer. It sat overnight due to the bad weather. Yesterday we tried to take it for a ride and it wouldn't start. %#@*&! At this point I think the dealer didn't prep the battery correctly or it's just a lemon of a battery.
    It was hooked up to the battery tender overnight so I will run some voltage checks on it when I get home after work today.
  3. #53
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Rando View Post
    Did you check it after it was hooked up all night? I hope it's just the battery. Like I said when we talked on the phone, so far your issues are dealer issues and not RT issues.
  4. #54
    Jun 2010
    Las Vegas
    Randy I'm sorry to hear you are still having problems. As Lamont said it sounds like things your dealer have done incorrectly. I hope that they get you on the road quickly. Are you planning on going to Spyderfest?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  5. #55
    Mar 2008
    Allegan, MI
    Michigan's Lemon Law doesn't cover motorcycles. You wouldn't have met the requirements yet, anyway. I know these teething problems are frustrating, but they should be able to be readily resolved (by a decent dealer), and you should be enjoying the new toy in short order. The weather has been too crummy to enjoy the Spyder, anyway. Hang in there!
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  6. #56
    Very Active Member IWN2RYD's Avatar
    Apr 2010
    Puget Sound, WA.
    Smile
    It breaks my heart when I see this. You are getting help from two of the best experts here I know it is tough to be patient at times, to bad I was not in your neck of the woods or I would stop by and have a look...
    BTW... A local member here had this issue with his 2010 Limited... Long story short... We unplugged and plugged back in all the relays we could get our hands on, snugged up all the grounds and he has been problem free ever sense.
    BlUe SpYder RT-S SE5 #303I don't suffer from insanity; I enjoy every minute of it ... Proud Member of A.S.S. (Average Senile Spyderryder)
    Our 2010 RT-S Mods... *Warning* If you can read this, it is already too late and there is no known cure. You have Spydervirus.
  7. #57
    Sep 2007
    Mesa, AZ
    Quote Originally Posted by Lamonster View Post
    It was on the charger for 5 hours and then I had to go to bed since I get up at 4am for work. After 5 hours it was still a steady red. This morning it was flashing green, indicating a trickle charge. I disconnected it and it was putting out 13.65 volts. I will check it again when I get home around 4pm.
  8. #58
    Sep 2007
    Mesa, AZ
    I just finished checking the battery. This morning, after sitting on the charger overnight, it was 13.65. Eleven hours later it was 13.02. With the key turned on, it was 12.46. Cranking, 10.87. At idle, 14.14. At 4,000 rpm, 14.14.
    Sounds like the battery just ran low after sitting at the dealership for 5 days? Ok to go for a ryde or is it going to leave me stranded?
  9. #59
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    I would think the battery with a full charge would not drop to 10.87 volts under load. Sounds to me it has a bad cell.
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
  10. #60
    Active Member BentGamer's Avatar
    Dec 2010
    San Jose, Ca.
    Quote Originally Posted by Y Rider View Post
    If it were me having those problems, I would put in a new battery. Especially if your concerned about being stranded.
  11. #61
    Oct 2010
    Springfield, MO
    How are you measuring the voltage? Did you have a volt meter with probes directly on the battery terminals?
    2011 RTL , White
  12. #62
    Mar 2008
    Allegan, MI
    No, the load test spec is 10.0 volts, or more. This battery tests out OK, according to the shop manual. The 12.5 volts after the key is turned on seems low to me, and may be the cause of the symptoms, but it does not have a spec in the book. The only reason I can think of for such a drop, as the computers and such fire up, would be a poor ground or other major connection, that increases the resistance under load, and drops the voltage as a result.
    -Scotty
  13. #63
    Sep 2007
    Mesa, AZ
    Positive on the battery side of Spyder. I pulled the red plastic cap off, negative on the ground opposite side of seat/battery location. I believe they are there for jumping the Spyder?
    By the way, the wife and I had a really nice ryde after I got off work today. She drove it out and I drove it back. We both enjoyed being a passenger since it was a first for both of us!
  14. #64
    Active Member redfox's Avatar
    Apr 2011
    Catskill Mts
    Curious if this was the end of the problem for you, Did the Battery hold the charge and the other problems go away as a result
    Thanks
  15. #65
    Sep 2007
    Mesa, AZ
    Quote Originally Posted by redfox View Post
    Thanks
    Yes, thanks for asking. It was in the shop yesterday for the 600 mile service and to replace the faulty turn signal switch. I was shocked by the amount of parts that had to be removed just to replace the left handle bar control assembly!
  16. #66
    Apr 2011
    Catskill Mts
    That's good about the battery holding it's charge and eliminating one set of problems, sounds like it was not preped right by dealer. Sorry to hear about the turn signal problem though glad they got that fixed for you.
    I have about 25 days left to sign up for the Best without the $75/yr surcharge, sounds like I better get it for the 3 yr additional warranty. I have about 450 miles on a new RTS, love it, but am very apprehensive about the electrical/electonics and computer brain on these machines. Had Harley's, Yamaha's, Honda's and Kawasaki's over the last 50 yrs with zero major and only about 2 minor problems. I never felt as fearful of electonic and mechanical problems as I do with this machine with the dealer 60 miles away. The 3 wheels have put me back on the road though. Wish it would stop raining so I could get more miles on it.
  17. #67
    Sep 2007
    Mesa, AZ
    I have about 25 days left to sign up for the Best without the $75/yr surcharge, sounds like I better get it for the 3 yr additional.
    Berts Mega Mall has the best pricing or do what I did and get your dealership to match the price!
  18. #68
    Very Active Member dancogan's Avatar
    Jun 2010
    SE Michigan
    Randy,
    Good to hear your enjoying the RT ... other than this weather we're having. We stood out in the rain for about 3 hours yesterday watching our daughter and son-in-law compete in the Grand Rapids River Bank Run. We were hoping to get in a long ride today ... NOT. I don't even want to look outside, let alone be outside.
    Anyway, hope to see you on the road.
    Dan
  19. #69
    Apr 2011
    Clinton TWP, Michigan
    HI guys have been reading the posts and would like to say that I also bought mine from C&C. Took it in for 600 mile service with some other issues. For one the right fog light was not working. Picked it up and when I got home checked the fog lights and guess what , right one not working. Called the dealer and told them it was still out and I wanted it fixed. They said they checked it and it was working when it was in the shop. I said well it wasnt before I dropped it off. You have to do more then just turn it on and by magic it works. You have to check the connections and bulb not just turn the thing on and say yep it works . Maybe I was dreaming and it really was working NOT. Back to the dealer to get it fixed.
  20. #70
    Registered Users JonGalt's Avatar
    Mar 2011
    Raleigh, NC
    [QUOTE=Lamonster;304834]Sorry you had trouble with your new RT but glad it wasn't too serious.
    This is the panel under the seat to access the battery. It's two screws.
    (just out of curiosity what is the top right round plug looking thing? Does it come out or need to? Can it made to be an after market power outlet? I tried to pry it off and felt like I would break it so I walked away defeated)
    _____________________
    Jon Galt
    2011 Spyder RT-S SE5 - OEM
  21. #71
    Mar 2008
    Allegan, MI
    Passenger comm system jack.
    -Scotty
  22. #72
    Mar 2011
    Raleigh, NC
    Quote Originally Posted by NancysToy View Post
    Thanks, guess I was just hoping.
    Jon Galt
  23. #73
    Mar 2008
    Allegan, MI
    Quote Originally Posted by JonGalt View Post
    If you bought this used, it could be a power outlet. Lift the flap and look inside. It it is a large opening with contacts on the side and bottom, it is power, if it has many small contacts, it is comms of some sort. It is the location for the optional comm port, but someone could have put anything there.
    -Scotty
  24. #74
    Apr 2011
    Catskill Mts
    I follow Lamonster's post about the 2 screws for accessing the battery to check connections on the battery. However if you had to completely remove the battery on a 2011 RTS could you get it out that way or do more panels have to come off. I have seen a tech take off the rear side panel after removing only the middle side panel. Would that be it or is there more stuff like the side storage compartment that has to come off to get the battery out. God I hope not but it looks like it to a novice. Will be working on it this week-end to check connections on the battery.
    Reason I am asking is we have a 2 car garage, Miata and Spyder occupy it in the summer. In the winter the 2 Subaru's have to go in there. We live in the mountains and have wicked winters. They use tons of salt and sand on the roads here so no winter riding anyway. We have great dry storage for the summer toys that we rent very resonably but no battery tenders are allowed, so I will have to remove the battery and keep it on a tender on the work bench in the cellar.
    Also any computer memory that could get messed up by removing the battery for the winter (5 months). Don't want Nanny to get mad in the spring.
    Thanks
