Originally Posted by dave01
And that was following Doc today. I was surprised .
Added the 2011 windshield and removed the lower winglets, tweaked the JB Pro a little and off we went today. Mostly highway, around 70-75 mph.
So far, my total average works out to 35.6 mpg over the last 2700+ miles.
What were you getting before you made the changes?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Sounds like you may have this one dialed in just right.
I gained a little over 2 mpg after the changes. Not a huge amount, but she is running great, no fuel fumes when running and still running at 4-5 bars today with 94 ( not correct) degrees on the air temp guage.
WOW
Originally Posted by freebob
My Chinese calculator tells me that at 35.6 mpg and 6gal. of fuel would be
a total of 213.6 mi. with the engine running, Hope your going downhill..
Freebob...
Your calculator did not take into consideration that he has a Fuel Safe auxiliary fuel cell in his front trunk. You should check out his mods thread, as it is very impressive.
Willing to share your JBPro settings? My mileage has been sucking lately.
corbin Lamont cut seat with back rest, graphic gator,Chrome grips, trailer hitch,buttler mug, two brothers exhaust, painted center fender strips. center brake light, Led lights, tricLed fender lights
You sure that isnt Kilometers per gallon ?
Yep. Like I said, I was a little surprised too but I check each tank when I fill up to see if any changes are working. Apparently, they are.
MY BAD....Guess your lights blinded me.....
Freebob..
Sorry about that. I got a call from the International Space Station the other day asking me if I could tone things down a bit. I told them I would take it under consideration, but probably not.
You forgot to mention tha long cable attached to Doc's trailer hitch and your RT....
Hmmmm....
I think your calculator is busted...Or...you have had a miracle bestowed upon your Rotax....Or...maybe it was down hill the entire 2700 miles... ... Len
Nope. I have been diligent on checking this each time. RPM's kept at or below 5500, speed kept at no more than 70, unless passing or catching up to group. Its just a test to see how personal throttle control, use of the cruise and fuel mapping can change the mpg of the rotax.
Sounds like a kinda boring way to ryde.... but then you have another ride for excitement, dont you ?
oh yes. The spyder is the cruiser.
