Fault Code P0707 ???
Got this code nultiple times this weekend, along with the "E" in the gear position indicator intermittently, and flashing "R" and "N" pilot lights.
When I got it to the dealer, the service manual didnt have this code listed, and the BUDS download showed it had not stored. I know I wasnt seein things, anyone got a clue what this code is?
Thanks in advance!
This issue has come up before, with no final answer that I am aware of. I don't believe you were seeing things. Hopefully, you can solve it. Wishing you the best of luck.
http://www.spyderlovers.com/forums/s...ighlight=P0707
Ryde Safe!
"There are two things you can never get back. A word after it is said and time after it is gone."
Originally Posted by Texmac1011
Thanks!!! Maybe we can get some resolution now that there are at least 2 of us who got it. Maybe we both won the lottery or somethin and get new Spyders...LOL
Littlejohn, in my manual I see 2 listings for PO730, which is the next listing in the manual where PO707 would be found. Is it possible that the first PO730 listing is a typo and should be PO707? It would seem to make sense in your case as the fault described is "Gear position sensor in invalid range". I would check this out.
Have you had the gear position sensor changed? That gave me the flashing indicator lights but no code.
2008 SM5, F1 EvoIII slide, Hindle, Race Air Flow System, O2 Delete, Fuel Pressure Modfier, Powerbus System, BRP 6 Spoke, 12V power supply x2, 1" Handel Bar Riser, CompuStar Alarm System w/pager, Mono Seat Cover, Brake Caliper Trim, Trunk Liner, Outdoor Cover, Carbon Fiber SM5 Handelbar Inserts, Carbon Fiber Tank Knee Pads, TBR Juice Box.
Sorry, my friend, but my wife and I are going to win the next lottery and get two brand new Viper red RT-S's loaded to the gills!!!
Mod Maniac
Thanks in advance!
Something about black wheels, I do believe.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
PO707
Hello i put a new gps in did the same thing.Went into limp mode doing about 100 went back to shop.Put it on buds said it was the sas.Been running great since last sept.So i guess it was the sas.I did put the sas in my self its a long story.Drove it back to shop to reset it.Still working.
Hah!!!!! Wanna buy em back! LOL
Thanks, Ill give the dealer a call and pass on this info when they open tomorrow., I saw on a couple Aussie forums that the gps fixed their issues on this one.
I saw that too. Ill look at it again tonight and point it out to the dealer so they can ask BRP about it.
Nope, not yet, but Ill bet thats in my future! LOL
Thanks in advance!
Guess what came back with a vengeance this weekend on my trip back from Austin.
Motorbike Professor
Standard code for leprechauns?
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
This is not good news LJ. As you know I replaced my GPS for the same reason last week with no improvement in dash display. WORRIED as due to going touring in 10 days.
Did it go into limp mode?
The best substitute for brains & knowledge is....................silence.
I read the info in this link which is the one LJ refers to I think.
http://www.ozspyderryders.com/index.php?topic=635.0
and explained below how I replaced the GPS 5 days ago but it still showed the gear display changing with the new GPS.
http://www.spyderlovers.com/forums/s...t=21441&page=2
Now I 've read where removing the key 'resets' something - it's been out of the ignition for a few days now. So I just took Spyder for a 30 min fast ryde and all is now as it should be - no changing gear display. Curious?
For the hour and a half that it took me to fit the new GPS last week, the key was in the ignition switch. I then took it for a test ride and found that the issue was not fixed, but yet is OK today. Curiouser?
So, I'm somewhat relieved but will go for a longer ryde in the next day or two, to be sure.
My question is - is there a reset thing which happens when the key is removed for a period of time?
Thanks LJ.
Hey Scotty, "My question is - is there a reset thing which happens when the key is removed for a period of time?"
Motorbike Professor
Originally Posted by Freddy
Thanks LJ.
I don't understand exactly how it works, or is programmed, but yes, to some extent. Removing the key and taking it away from the vehicle (for at least 15-30 seconds?) allows the cluster to reboot clean, resetting limp mode and any errors that have cleared. Active error codes on start-up will trigger limp mode again, however. This is not really a complete system reset, just a clean boot, as far as I can tell.
-Scotty
Thanks for that Scotty. I guess that's the only plausable explanation for the odd experience I reported in the other thread after fitting the new GPS. I just got back from a 1 hour ryde and all is in order - thankkfully! Curiouser and curiouser this Spyder thing.
Update
Just to keep yall updated on my issue.
Got a call from the Svc Manager today at the dealer, he forwarded my picture and video of the infamous P0707 fault to BRP, and they now agree Im not smokin crack. They OKd a GPOS replacement, and its now on order. They are also supposedly starting a campaign to see how the computer generated its own code that they had no idea existed...LOL
Ill let yall know what I find out.
Motorbike Professor
I still say it is leprechauns. Not sure if they are familiar with those in Quebec.
-Scotty
Thanks for the update LJ. Generated it's own code eh? ....'no idea' seems an accurate comment. They obviously don't read any of this forum to know of the misprint in the manual - or are all newbies. They must be kidding - I hope.
This is very inspiring.
