Results 1 to 18 of 18
    Apr 2009
    Ft. Lauderdale, Florida
    Red face "Warning" RT Owners
    I found out the hard way. I put my GPS and my LED controler in the box on the top in front of the set on my RTS. Well it got so hot it did destroy all the electronic's in those items. Once in awhile I would put my IPhone in there also. I wounder why it would freeze up and didn't know why. Now I know. Please learn from my mistake.
    PS
    No chocolate bars either.
    Oct 2010
    Somewhere out there...
    Question
    Quote Originally Posted by Spyder#353 View Post
    PS
    Not sure if I understand exactly where you placed these items...
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    sound like the glove box
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Red face
    I believe he's talk'n about the "GloveBox" on the RT. The compartment right in front of the saddle and between the saddle & the handlebars.
    It gets rather hot in there, as we've learned that by trying the chocolate scenario he mentioned
    Dave & Teddy
    Oct 2010
    Quote Originally Posted by CyncySpyder View Post
    Dave & Teddy
    I don't even carry chocolate in my pants!! There I have my garage door opener and my clear lenses for night ryding!
    Jun 2010
    Las Vegas
    And that is why they call it the "Top Oven".
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Springfield, MO
    Sorry to hear that, I use mine to warm these.
    Dec 2008
    Jacumba, CA
    That may be why it is called a "glove box". It has been my experience that when anything is enclosed and left exposed in the sun without any insulation, it will get hotter than the surface of the container. I do not own any electronic gadgets for the RT, but if I did and removed them for security, I would put them in the deepest part of the rear trunk and cover them with something to provide insulation. I would also not leave them for an extended period of time in direct sunlight.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by stevedfive View Post
    Mine was hot also so I just had my dealer install the "glove box heat shield kit". A recommendation from Nancy'sToy.
    I didn't recommend it, I just explained it. I never had these components on my PE RT. I'll probably remove at least the insert on my 2011. I carry sunglasses, anti-fog paste, sunscreen, and an insect repellent stick in my glove box. All traveled well...but I don't live in a scorching hot climate. I wouldn't carry electronics there, not even a garage door opener. The space gets heated from both below and above.
    Aug 2010
    Riverside, California
    I stand corrected, my bad.
    Jul 2010
    Waterboro,ME
    On some RTs the glove box came thru without the insert or insulation underneath. I have kept my camera in mine with no problems. Definitely would not put chocolate bars in there nor anywhere else on the bike.
    RT-S PE#0180
    Oct 2009
    St. Joseph, MO
    Default Insulation for cure
    Try these parts to help heat problem.
    Exterior Front Insulation Foam Part # 705004427
    L/H Insulation Foam Part # 705004428
    R/H Insulation Foam Part # 705004429
    Heat Shield Part # 705004424
    Internal foam Part # 705004426
    First 4 parts applied to outside of compartment and require disassembly of center compartment (good size job).
    Last part is an insert for the compartment.
    I have all 5 on my Rt and it helped a lot.
    Good Luck
    Quote Originally Posted by rogerb View Post
    The chocolate bars are safely stored in my belly!
    The garage door opener gets thrown in the oven...
    Jul 2010
    Huntsville, Al
    Default top oven...
    Quote Originally Posted by Lamonster View Post
    ...or just enough room for two Krystals.
    Safety Harbor, Florida
    When I had mine apart to install the CB, I wrapped the glove box in insulation. It still gets warm in there...but no where near as hot as it used to get.
    Invalid Emails
    Jul 2010
    1/2way tween STJames and Salem Mo
    Wink "Glove Box" VS Oven
    OMG that's were I have been putting my garage door opener!!! Will put it in shirt pocket from now on!!! Or hang it on a string around my neck. On my RS I could hang it on the wires over by the throttle.( haven't got stock handle bars so wires are out and easy to hang it on) Anybody got a good area to put it where one could get hold of it easily???
    Apr 2010
    Puget Sound, WA.
    Wink
    Darn it.... I knew it sounded funny when my wife told me to place it on my head while driving. it belonged in the glove box!
