Please help, what is the best tire pressure?
What have you found to be the best tire presures for the Se5, stock tires, 240 pound single rider?
Senile Member
Do a search on tire pressure and you will find a wealth of knowledge and preferences. It's an old topic
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
Motorbike Professor
You need to find the best pressure for your spring settings, weight, style of riding, etc. For most of us, 18-20 front & 28-30 rear seems to be a good place to start with stock tires. It will make a big difference in cornering when you raise the fronts above the BRP recommendations. I think you will like it! I would not recommend running too high in the front, even though they are rated for 30 psi. Also, I would not recommend running below the 15 psi minimum printed on the front tire sidewalls. Remember, tire pressures are to be checked cold...no matter what Kenda says.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Tire pressures, like revenge, is a dish best served... COLD!! Scotty, that was my conveluted way of agreeing with you!
BTW, a pretty good link regarding tire pressures. I think you'll find a pretty mixed bag of ideas and opinions on this matter...
http://www.spyderlovers.com/forums/s...=tire+pressure
"Life must be understood backward. But it must be lived forward."
'09 Phantom GS (#14) (Gone but not forgotten) and 2010 RS-S
Around 17 fronts and 26 rear works great for me.....
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
Is anyone using "TireGard" for monitoring tire pressure? They are expensive but I have seen a wide range of prices, from $179 to $279 for the Trike version.
Sent from my DROIDX using Tapatalk
Accutire: http://www.spyderlovers.com/forums/s...ad.php?t=19396
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
Alignment Specialist
16/26...more than that and I think some are getting uneven wear issues...
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
I've got the Trike Tireguards. Little diagram is backwards but I think its a great gizmo. The other night the little alarm went off because my rear pressure was too low. That's a nice feature.
What about concerns that the plastic will bend/break with the added weight from the monitor on the stem, causing a major issue?
Bone Crusher
The sensors are very light and I have never had a problem. I was not aware of any issue until you mentioned it.
I checked some other boards and some have had tire blowouts due to the stem breaking...I think there is some concern with this but I'd figure we'd be better off as our tires don't lean, thus changing forces on the stem all the time?
Bone Crusher
I read somewhere that to avoid stem breakage you should change over to medal stems.
I think I'll wait on the purchase until they correct their trike picture...
tire guard
I tried them on a GS and found they throw the balance off..after removing the sensors the wheels had much less bounce and is much more smooth.
But that is a pretty cool-looking thing! I've got a buddy with a Tri-Glide and I'm going to have to see if I can get him to part with some coin for one of them...
I ran over 250 mi with them on my RT this weekend, speeds up to 85 and never felt any different than before. I sure like them. Being able to also see the tire temp is interesting also.
I'm over 300lbs. and my dealer set the pressure at 20 frt. and 30 rear.
My Heaps:
2010 Spyder RT-AC SE5
1987 BUICK Turbo T - TURBO SBC Project still in the works - (11.3 @ 121 without the turbo installed N/A)
RIP - 1982 OLDS CUTLASS 11.02 @ 129.2mph
Sold -- 1987 BUICK Turbo T W02 11.61 @ 118mph
Sold -- 2004 DODGE SRT-4 S2 13.0 @ 111.9 mph
"...there's two dates on your tombstone and all your friends will see 'em,
but the only thing that matters is that little line between 'em..."
I run the same pressures as you. I weigh 178#.
I had a vibration from 55 mph -62 mph whether I was in 3rd, 4th, or 5th; I have an SM5. So, I set the pressures back up to 20 fronts and 30 rear and the vibration seems to have just about disappeared.
Anybody calibrate their Air Gages, I have 3 different gages that show 3 different readings,
So for the last 3 years i just stick with one and guess.?
Pencil type air gauges are unreliable. I use a Moroso dial type with a bleed off button.
The gage that came with my Spyder, Reads = 19
Brookstone Precision=15.5
Acme= 20,
I Only use the pencil type to scratch my back.
The Brookstone and Acme are bleed type.
