Originally Posted by Motavar
I have an 09 Phantom GS - SM5.
Which is a RS. It's all the same crap.
So the bulb fires in only one of the front blinkers but not the other.
And you flipped the wires? When you flipped the wires.. does the original bulb still work in that spot? Yes
There has to be a way to make it work.
Do you have a web link for the type of LEDs you purchased or did you pick them up from a store? I got them on ebay, but I have tried a few different wattages to no avail.
Would you happen to know the wattage?
The last ones were 12w but I've tried 1w..
I believe I recall from other threads that Nanny uses different parameters in the SE than the SM.
Any chance you could take a picture of the bulb from the bottom. Is it a 7507 BAU15S connector with 1 dot on the bottom and 2 points on the side at an angle ?
* do you have a link from the ebay auction you got it from by any chance?
* what resistor did you use?
* Did you happen to replace the blinkers in the back of the spyder or are they stock?
Any chance you could take a picture of the bulb from the bottom. Is it a 7507 BAU15S connector with 1 dot on the bottom and 2 points on the side at an angle ? Yes
* do you have a link from the ebay auction you got it from by any chance? No
* what resistor did you use? led load equalizers-25w 6.2ohm
Stock
Nice work Motavar.
Thanks for sharing your solution to the LED conundrum....
Originally Posted by Campverdefela
Stock
My LEDs were 7w vs your 12w. hmm.
Okay do this..
Put your stock turn signals back in both front blinker spots.
I'm guessing you already cut the wire that went to the turn signal and prob have it taped up. un-tape and then try to light up the LED with the bare wires from the turn signal. Make sure you have the wires still connected to the stock turn signal.
So you should have 2 stocks running and bare wires hanging out so you can attach the LED to get it to light. The LED should light up. We're only talking an additional 12w (or 1w) depending on which LED bulb you selected.
Let me know if that works.
PS: reason I asked for who makes the LED is maybe I can order one online and try it out. There should be a way to get it to work on the Spyder.
Okay do this..
Thanks, I'll try that.
Take the brake light connector off the Spyder
Remove the shrink tubing that protects the 3 wires
Look at the connector and note wires #2 and #3
You will hook the resistor up to these wires.
Is the wire coming from pin 1 for taillight? Would use that for alarm system, if so.
V-LEDS AMBER 20 LED 7W BLINKER/TURN SIGNAL LIGHT BULBS 7507 BAU15s
Will these bulbs work for rear blinkers on a spyder RSS? do u have to install new module's ?
For the blinker I chose the following bulb from v-leds.com
BRAKE LIGHT INSTALL:
For the brake light I chose the following bulb from v-leds.com
V-LEDS RED 92 M-SMT TAIL/BRAKE LIGHT BULBS 1157 2057
You can see the size difference from the original bulb.
Will it fit? Lets find out!
We have plenty of room
Picture inside the housing
Turned the lights on to see what they look like.
Hot resistor.
The resistor will get hot. To the point where you will burn your fingers
Great post Motovar.
The engineer in me finds this unsatisfactory. One reason for fitting LEDs is to reduce heat. It is normally radiated inside the lamp housings where you can't feel it. Moving it to a resistor seems to defeat the purpose of using LEDs.
It should be possible to use an electronic ballast to draw the current that is excess to the LED lamps' needs, and shunt it back to the battery with much lower overall dissipation.
I have a rough circuit sketched out of a buck/boost regulator that would draw a couple of amps and shunt the current back to the battery.
My record of acually building these things is rather dismal though, so it might take a long time before I try it out. Is there anyone on the forum who would like to make one up and try it?
Pogo.
