Page 1 of 5 12345 LastLast
Results 1 to 25 of 116
Thread: RT ACCIDENT
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    Default RT ACCIDENT
    Buddy of mine and his wife were involved in a single vehicle rollover TC about 4 hrs ago on their RT. They are OK but bruised. Apparently he made a left turn and was going straight when the violently steered to the right taking the handle bar out of the operator left hand, rolled on its side, throwing the ryder and his wife then uprighting itself. The RT DID have the recall performed apparently. This info was relayed to me by a ryder who witnessed the event from behind.
    Has ANYONE had ANY problems since having the recall performed?
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    Eastern North Carolina
    Man, thats gotta be scary as h _ _ L Hope they are going to be ok. I seem to recall someone else posting a similar problem after their DPS fix, but not as violant. Makes you think...
    Jun 2010
    S.F. Bay Area
    I hear you Bruiser. Just when you think you can start to relax a little bit about this aspect of the machine it raises its ugly head yet again. I hope that couple will be back to normal soon.
    Seems there have been a few posts recently regarding post-recall DPS issues but they appeard to be more related to actual work performed and not the unit itself. Although it's no secret that many here have gone through multiple units as well. So yes it does make you think a little bit...
    Nov 2010
    Lower Saucon, PA
    Scary stuff, I'm glad they are okay.
    Not to hijack this thread but how does the DPS work? Does it have a sensor that detects which way you are turning then engages a motor to assist in the steering? If so, could those sensors be sticking?
    RT-S PE#0391
    Dec 2009
    Columbia, MD
    Default Hang on ...
    Thanks for the report. Please encourage this ryder (who I'm glad is okay along with his passenger) to post exactly what it seemed happened, as well as what happened mechanically. The report says 'made a left hand turn and was going straight' when the accident happened. So, my mind ponders ... Did the turn have anything to do with it? Was he just running straight when the RT just whipped to the right? Where did the mishap occur and what were the road conditions? This could also be a mechanic error. The last time I ever saw something as severe as this (not on a Spyder), the steering gear assembly came loose.
    So respectfully (and I mean it), I kinda go back to the out-breaks of stories on Spyders burning. We never quite understand the previous history of the machine or particulars about recall activity. Again, I'd really hope we hear from this ryder.
    I've got 6300 miles on my RT-S ... still have the original DPS. The DPS recall is a voluntary recall on the part of BRP/CanAm. They are not saying there's anything wrong with the original RT DPS; but have volunteered to replace the original with a better performing part (conspiracy theorists ... please stay calm). I've certianly had no problems. I'm currently No. 2 on the list for the DPS recall at my dealer in MD. Interestingly, I've been No. 2 since before Thanksgiving. As many know, the way BRP is working this is that now the dealer must do a DPS replacement, send in the old part; and BRP sends them a new one. They've not been able to get in a new DPS since their last DPS recall job in late November. I suppose that has me going 'hmm.'
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Glad your friends are OK
    Apr 2010
    Wesley Chapel, FL
    Quote Originally Posted by Marker View Post
    Nov 2010
    Lower Saucon, PA
    Thats why I posted the question on how the DPS works (does it have contact sensors?).
    If the driver makes a left turn (left sensor gets pressed in) and then goes right to straighten out (right sensor gets in). Did the right sensor stick?
    Then the driver will probably steer left again to make sure he/she is going straight (left sensor gets pressed in but right is still stuck so the computer says you can't have both in at the same time so we will go left and wait a sec for right side to clear?)
    Computer waits a sec then detects the right sensor still activated and turns right = flip ?
    Invalid Emails
    Jul 2010
    Fairfax, VA
    Wow, that's scary! I'm so glad they're okay though.
    I had the DPS recall done in November. Right before Thanksgiving. I hadn't had any problems but, I had my Spyder in for it's check up so they went ahead and did the DPS.
    My husband and I rode down to SC a couple of days later to spend Thanksgiving with his brother and family. While down there, traveling about 55 on the freeway, my RT suddenly veered to the right. I brought it back to the left only to have it happen again about thirty seconds later. Scared the heck out of me! We stopped and called our dealership to see if they could locate a shop near where we were staying. Lucky for us there was and we took it straight there. They hooked it up to the computer and found that after replacing the DPS our shop had failed to reset some sensor. I can't remember what he called them. My husband wrote it all down but, I can't find the paper right now. The tech reset the values and so far I haven't had anymore trouble. Can't help feeling a little nervous after hearing about this accident......
    Jun 2010
    S.F. Bay Area
    Quote Originally Posted by HDXBONES View Post
    Respectfully, please perform some searches here, you'll find out more than you ever wanted to know about the DPS system........
    The short answer to your premise is, no, that's not how it works. There is a 'Steering Angle Sensor', which measures movement and direction, in degrees from center, and is which also an integral part of the stability and traction control systems.
    Glad to hear that the couple involved were not hurt seriously.
    I did just that (search that is) and was particularly interested in a thread regarding the subject that you posted on 3/2010. I feel as though in reading that thread and others that you have a good handle on the situation.
    Since that thread the story has evolved, BRP has released the Gen 2 unit into the wild and so far it appears that the new unit is in fact working; the friction issue that caused the problem in the first place has been solved. My only nagging concern at this point is in regards to the software, or OS as they call it. Are there unfound bugs that still haunt the system?
    The other factor that has to be considered is the dealer network's ability to correctly perform the work. BRP should be making sure that proper training is being supplied so that this most critical procedure is done right the first time, every time.
    One other thing; BRPs Outlander XL ATV family has a dual-mode, rider selectable DPS. I wonder if that community is experiencing the same phenomenon? Obviously the steering and suspension geometry is different so maybe not. But these vehicles also do not have (to my knowledge) VSS, TCS, and other systems that have to inter-act and share cycles with the computer. SO if the Outlander is clear of these incidents, they should look at that.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    To clear up the confusion about the sensors, there are two involved with the steering. There is a steering angle sensor to sense the handlebar position, and a steering torque sensor to sense the steering effort. (and direction?) The computer uses these readings, along with the vehicle speed, to determine the steering assist that is appropriate and necessary. The most common cause of a steering problem that is not related to DPS failure, is a mismatch between the zero settings of the two steering sensors, or zeroing them without properly centering the handlebars. Sensor failure or improper adjustment (via BUDS) can result in failure codes, limp mode, and/or steering irregularities. A power failure to the DPS can cause a lack of power steering. The VSS utilize inputs from the ABS wheel sensors and the yaw sensor, among other things, that also may also affect the vehicle direction. There is no way, based on the information given in this report to tell just what may have failed, been improperly installed, or otherwise have caused such an excursion. Scary stuff! Glad everyone survived! Lets hope the dealer finds a cause, and eases everyone's mind.
    Jan 2009
    Northwest Arkansas
    The RT service manual, starting on page 513, explains how the steering works. Its a good investment, about $10 for the manual on CD from Ebay. For example, did you know the steering assist stops below 14 degrees F, works above 14F, gradually decreases as temp rises, and stops again over 185F, and that after exceeding the temp range then coming back into range, you turn off the bike for 30 seconds to reset it? (I don't know if this is true with the revised DPS)
    2015 F3 SE6 , White - The fastest color!
    Oct 2009
    Martin, SC
    I hope your friend and his wife will make a speedy recovery from this. Please keep us updated on their progress.
    Quote Originally Posted by 2WCKED View Post
    More than likely your shop failed to reset the Steering Angle Sensor, as we have seen that problem pop up on here quite a few times before. They have to follow the exact procedure, and for whatever reason some seem to miss that step. Once it has been reset, as yours was here in SC, most people have not reported any more problems with it. I am definitely hoping this is the same for you, and you will have nothing but smooth ryding from here on out. By the way, what dealer in SC did the reset?
    Invalid Emails
    Apr 2009
    barstow,ca
    Unhappy Drop them in Ocean
    I was following the couple who had the accident on the RT . They had completed a left-hand turn was going straight about 15 to 20 mph when without any notice the RT turned turned right without any notice causing the L/H tire off the ground causing the RT to turn over in the couple being thrown from the RT . I was only 15 feet behind the couple when I pulled over engine was still running in the RT was still in first gear is my personal opinion that the DPS caused this accident and BRP to should take responsibility I also believe it's about time that all SPYDER owners Sue BRP for the what they paid for the spyder and take all existing SPYDER and drop them in the middle Atlantic Ocean because they are becoming a death trap . We'll you be next ?
    Invalid Emails
    Jul 2010
    Fairfax, VA
    Quote Originally Posted by SpyderWolf View Post
    Yes, that sounds like it. The dealer was PowerSports of Greenville. They were great. It was the day after Thanksgiving and we were in and out in about an hour.
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    Default my new DPS
    I just got my new DPS installed, steers much easier than before, almost too easy. Before it used to understeer, now it seems to oversteer slightly. It seems like it would be able to dodge a pothole or something in the road much better at speed than before, seems to have more assist at higher speeds, seemed a little sluggish before. I was happy with the old DPS, but the new one is much better, I'm happy. Had both updates done, that went well also, and seems to shift much easier. They said i need to keep a closer watch on the oil level, that i was 2 quarts low, i said "i don't think so" when i got home and looked at the oil stick it was 1.5" above the full mark!
    Oct 2009
    Martin, SC
    Thanks for the info. That dealer is a good 3 hours away from me, and I haven't been there yet but will make it a point to stop by next time I am ryding in that area.
    Alignment Specialist
    Aug 2008
    MD
    Quote Originally Posted by spyderflyer View Post
    Wow, you're saying the bike was going straight and then all of a sudden the bike just forcefully turned right enough to force the tire off the road?...over-riding the VSS system? I think the original GS/RS concerns with the DPS were sticking issues when going into a turn...I've never heard of the bike just forcefully turning itself off to one side...this sounds quite odd!
    Invalid Emails
    Apr 2009
    barstow,ca
    that what happen
    May 2008
    Clearwater, FL
    Quote Originally Posted by capt.jim View Post
    way to easy to steer at triple digit speed.
    Invalid Emails
    Apr 2009
    Brazoria,Texas
    Default ????
    Am I missing something here? I don't understand how the Spyder making a right-hand turn could lift the left tire off of the ground.
    Aug 2007
    Springfield, MO
    I'm very sorry to hear this. I hope they heal up okay and they can nail down the cause of the accident. I'm sure BRP will be just as concerned as all of us.
    Scotty explained the operation of the DPS very well. I do know from personal experience that if the DPS is not zeroed out correctly after being replaced that the torque sensor and the steering angle sensor will fight each other. This will be less likely to show up if you're doing a lot of turns because there is less to reference but you'll notice it more if you're heading down a straight road with little variations in your steering. That gives the computer time to check the angle sensor and to try and make corrections with the torque sensor. I believe it can be no more than 4 degrees out of calibration. I'm sure Len at Cowtown could tell us what is required by BRP to properly setup a new or replaced DPS.
    Dec 2008
    Syracuse, NY
    But, before you toss your spyder into the ocean, let me take it off your hands.
    Very Active Member SpydermanCT's Avatar
    Nov 2010
    Connecticut
    My thoughts and prayers go out to our hurt Spyerlovers and I hope for a full and speedy recovery. What ever the outcome of why this happened I hope they can continue to ride and enjoy their dream of touring.
    SpydermanCT
    2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
    Oct 2009
    Martin, SC
    I understand your concern after witnessing the accident in person, but the last thing we need to do is spread fear, uncertainty, and doubt, as to the cause and whether all of us are in immenent danger. Suing BRP and dumping all of the Spyders into the ocean will not solve anything.
    As Wyliec stated, if you no longer feel safe on your RT, there are many who would be more than happy to buy it from you.
    In the meantime, it is up to each individual to asses the amount of risk they are willing to take in their own lives. There are inherent risks in everything we do, from walking across the street, to eating different foods, to driving any type of vehicle. This was an accident, and accidents happen from time to time. If you tripped over a curb and broke your ankle, would you want to sue the city to remove all of the sidewalks?
