Page 4 of 4 FirstFirst 1234
Results 76 to 99 of 99
  1. #76
    Aug 2007
    Greeneville, TN
    Is this what people are using?
    I can't find any specs on this product. I can't see any viscosity numbers on the container.
    I can't find anywere on the BRP site that says this oil is 5w/40. They just say it is recommended for the Spyder.
    Some retailers say it is 5w/40. But I'm wondering if they say that because BRP recommends 5w/40 and they just assume that is what this is.
    Are there specs on the back of the container?
  2. #77
    Registered Users JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    Looking at the bottle I have it does not have any specs even on the back as you suspected. It only states it good for the BRP .
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
  3. #78
    Aug 2007
    Springfield, MO
    XPS
    X‑tra Protection
    (Part Synthetic)?
  4. #79
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Lamonster View Post
    XPS
    X‑tra Protection
    (Part Synthetic)?
    EXACTLY!
    BINGO!
    You Nailed it right on the head! Exactly where I was going!
    And Guess What! That is a 10w/40 oil, bet your bottom dollar on it! And that, my friends, explains why there is no viscosity rating on that BRP bottle.
    The Castol runs around $5 a quart in quart or gallon sizes.
    From what I've been able to find, you'll pay about twice as much a quart for the BRP oil.
    If this theory holds, you're paying about $5 for the oil and $5 for the BRP bottle. You could do the same thing by getting the Castol and just throwing a $5 bill in the trash everytime you put a quart in.
    Just food for thought.....
  5. #80
    May 2008
    Shawangunk, NY
    Post
    Quote Originally Posted by IWN2RYD
    ... I looked at Amsoil and it looked like this same dilemma is there as well. They qualify for numerous ratings.
    +The AMSOIL motorcycle oils (all pure synthetics manufactured right here in the USA) are NOT SM rated. There is no AMSOIL dilemma, and they're perfectly suited for a wet clutch environment.
    Ride on.
    Roadkill
    http://www.roadkillonline.net/imaged...s/35_10319.JPG
  6. #81
    Registered Users SpyderWolf's Avatar
    Oct 2009
    Martin, SC
    XPS
    X‑tra Protection
    (Part Synthetic)?
    X-tra Profit Sucking.
    Very Happy Spyder Ryder!
    Click here to see My Spyder Mods
  7. #82
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by SpyderWolf View Post
    Now, if we go 1 step further with this, and why not, we've already stepped off the cliff. Here we have the BRP All Climate, full synthetic oil. Again, with no viscosity numbers that I can see.
    Could this be Castrol Power RS Racing 4T Full Synthetic 5w-40 or maybe 10w-40? I strongly suspect it is.
  8. #83
    Way2Fast
    Guest
    I fail to understand why so many have their feathers fluffed over what oil to use. The Spyder engine is no different than any other motorcycle engine and just about all bike engines made today use wet clutches. ANY motorcycle oil that is labeled "safe for wet clutch applications" is perfectly acceptable for use in any bike, the Spyder included. 5W-40 or 10W-40 are both OK to use. BRP had been using Castrol oil for years. When they got a "better deal" from another mfg they switched suppliers. The Castrol oil was green in color, the new supplier's oil was brown. They may have switched back to Castrol oil or perhaps to yet another brand. They buy from whoever gives them the lowest price. The almighty buck is more important to BRP than the quality of the oil. There is one oil that I would never use in any vehicle.....it's BRP's XPS oil !! They don't put the rating designations on the container because they switch suppliers so often that they don't know what the current rating are !!
    On another note.....synthetic oil has an expiration date. It might not be wise to use oil that has been sitting at a low volume dealer for years. While it might have the designations you want, it probably will not perform as well as the latest batch of oils and might even be harmful to your engine..
  9. #84
    Mar 2008
    Allegan, MI
    When I looked this up on the BRP Website, it was not listed as recommended for the Spyder. I am guessing it is a wider viscosity range.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  10. #85
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Way2Fast View Post
    I'm not sure it's so much people getting feathers askew over a particular oil. I think we all understand it comes down to personal preference and opinion.
    Instead, I think people just want to know the truth. If they can get a straight story then they can make their own, informed decision. If the truth is that the current oil they use isn't what they thought it was, or if they find a oil they like better, I'd say most will switch.
    After all, it's the Spyder that is most important.
    Ruffling comes when things get confusing (and it appears the confusion may be deliberate).
    But I completely agree that the BRP oil containers lack details because they want the flexability to change what is in the bottle without having to change the container.
    I'm also sure BRP will not put anything into the bottle that isn't going to work well in the Spyder. But worrying about 5W or 10W is something that I'm pretty sure BRP does not waste their time on. My guess is you could get either out of the same BRP container, depending on when you buy.
  11. #86
    Very Active Member IWN2RYD's Avatar
    Apr 2010
    Puget Sound, WA.
    Wink
    If the ruffled feathers comment is including me, than so be it. I raise my hand in recognition... The act of ruffling feathers is to clean off the crap/worthless stuff . Or to attract the opposite sex of course .
    Baja is correct. I think most of us simply want what is best for our Spyders. Not some brand fan club. But to those like me who have not learned any of this information, but enjoy changing our own oils and such want accurate info. Period.
    I come from a family that usually keeps the same vehicles until either life changes create a change, or an accident or health takes them away.
    So for us choosing to trade in our 2010 on a 2011 was a real serious conversation, and is with the intention of having this for far more years than some may consider ideal. We simply do not want to start off it's life with us only to learn a few years down the road that we caused unnecessary damage to it. And could have prevented it.
    Talk is cheap, time will tell. But we plan to ryde for quite a few decades yet. Dropping $30k every few years to do that, or $3000-6000 to repair an non-warranted item is not on our agenda. Ryding with good folks creating fun enjoyable memories are...
    With this new added info on BRP flip flopping (Potentially) I am about to throw my hands up in defeat/disgust as an owner.
    I have read more than once, that changing your oil brand is not a good idea from oil change to oil change. As one brand has additives that another may not, and they can create a reduction in that oil change life cycle as the new oil is fighting the additives of the old. Evidently this can simply mean a 3500 mile oil change simply needs to become a 1750 mile oil change and from there you are good to go until you change brands again.
    Assuming this has any truth in it as well, if BRP is flip flopping I can see this creating a potential hazard and I would rather take it into my own hands and run the same product. And I have learned from this thread that buying a year supply of oil is not a good idea anymore if using synthetic oils.
    But then that is the very reason this thread got started now isn't it. lol... Mobil 1 Changed the specs (AKA selling points ).
    Man this reminds me of when my wife asked me to marry her. Circles after circles of thoughts hahahahahahahaha...
    If anything else, I for one am glad I chimed in. I have learned quite a bit. Thank you all...
    Off to surf the web for accessories. Man that is a lot easier
    BlUe SpYder RT-S SE5 #303I don't suffer from insanity; I enjoy every minute of it ... Proud Member of A.S.S. (Average Senile Spyderryder)
    Our 2010 RT-S Mods... *Warning* If you can read this, it is already too late and there is no known cure. You have Spydervirus.
  12. #87
    Very Active Member AMTJIM's Avatar
    Jun 2008
    Vail, AZ
    Yeah I know...high octane fuel and nitrogen in the tires.
    In the twisties I was playing the tart...
    2009 GS SM5 , Red/Black
  13. #88
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by AMTJIM View Post
    Yeah nitrogen in the tires.
    I find my Spyder runs best if i keep the Nitrogen level at 78 and the Oxygen level at 21 Percent in the Tires.
    And so far it's Tax Free.
  14. #89
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by IWN2RYD View Post
    Changing brands years ago was more of a risk than it is these days. And even then, I'm not sure it was all that big a deal.
    As long as you are staying with similar service products, it isn't going to be a problem. There are cheap oils, cheap additives, expensive oils and expensive additives. But again, if you stay in the same ballpark you're not going to have any chemical reaction.
    Now, if you add dyno oil to synthetic you will degrade performance. But that will be the result of mixing in an inferior product, not because of incompatabilites or chemical reactions.
    I wouldn't worry much about this aspect.
  15. #90
    Very Active Member Raptor's Avatar
    Jun 2010
    S.F. Bay Area
    Quote Originally Posted by retired1 View Post
    I just got back from my dealers Christmas party. His BRP oil arrives on Castrol pallets.
    That woud make sense as I am pretty sure BRP and Castrol oils are made by BP.
    "Life must be understood backward. But it must be lived forward."
    '09 Phantom GS (#14) (Gone but not forgotten) and 2010 RS-S
  16. #91
    Very Active Member clueless's Avatar
    Jul 2010
    Pittsburgh, PA
    Cool
    BRP oil is just like Harley brand oil. they get who ever bids lowest to make it for them.
    but Harley does say that they have a formula or spec that the supplier has to meet in order to mfg the oil for them. i.e. the oil is the same standards just mfg by different vendors for Harley. (that is what they say). at least they give you the weight of the oil on the bottle along with full synth or standard oil option.
    anyway this is where i get off the bus for this thread
    I am sticking with Motul 300V 4T.
  17. #92
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by clueless View Post
    See! There you go! Asprin goes back in the cupboard and life is good!
  18. #93
    Invalid Emails
    Aug 2007
    The Berkshires, MA
    Quote Originally Posted by HDXBONES View Post
    Ha!
    When I saw this photo, Lou, I thought that was you leaning into the turn and that you had replaced your RoadGlide!!!
  19. #94
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by jeuchler View Post
    Ha!
    What!? That's not a Road Glide?!?
  20. #95
    Invalid Emails
    Aug 2007
    The Berkshires, MA
    Not me, but I did replace my RoadGlide......with a newer RoadGlide.....
    Nobody tells me anything...
    Good luck with it, man!
  21. #96
    Jul 2010
    Pittsburgh, PA
    hey weren't you getting off this bus before me
  22. #97
    Aug 2007
    Greeneville, TN
    The bus I was referring to was the circular issue of warranty concerns, I love the oil bus!
  23. #98
    Dec 2008
    Syracuse, NY
    I don't have any warranty concerns. I let the dealer put the so called BRP XPS in. I don't think about who actually produces it, what the weight is or any additives. And, I know it would be cheaper to change my own oil. But, then I would have to be concerned about all the info presented in this thread and then I would have to worry if I had an old batch, a new batch, an in between batch with this additive or that additive.
    I just love to ryde and not have to worry. Isn't life great.
    Ron, you made me say all this.
  24. #99
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by wyliec View Post
    I am innocent of this charge!
    Everyone has to do what works best for them.
    I enjoy changing my own oil. I lean more about my ride, I know that it has been done correctly so I don't have to worry about somebody else doing it wrong (except when I let Lamont do it and he leaves the copper drain plug seal off the crank case just before we leave for a 5000+ mile round trip to California!).
    But I digress!
    I am able to use the best possible oil and still put a lot of bucks in my pocket to buy other things with.
    I don't have to ride 50 miles 1 way and wait for a service either.
    And, I know there will be zero warranty issues because of the oil I'm using.
    It's just the way I like to do it. And I think it has many advantages. But I know it isn't for everyone.
    Those that do it another way think their way is the best. I think my way is the best. But really, the way the Spyder owner likes to do it is best for them.
