Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 151 to 175 of 215
  1. #151
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Wow, now that sucks! Sorry to hear that and glad you are okay!
    Sounds like a law suit to me.
  2. #152
    Very Active Member TexasSpyder's Avatar
    Apr 2012
    USA Andrews, TX
    Will anyone be selling the BajaRon links at Spyderfest?
    J. D.
    2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
  3. #153
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by ncll View Post
    I had a Baja Ron Sway bar installed on my 2013 RT-S, Big change for the better. I had the Heim links changed by the dealer on a recall. Big mistake to trust the composite links. Should replace with Baja Ron links.
    Yesterday in the apex of a turn the stock heim link failed. The result was a crash into an on coming SUV. Some how I bounced without injury but the repairs with be in the $6000 range and down time 2 months. Crap stock links.
    Has anyone checked to see if the links were actually changed and if so that the current links were NOT the recalled version? Has someone visually verified that a link broke?
    I am very glad to hear that you were not injured. I am very sorry to hear that your Spyder was.
  4. #154
    Registered Users Dragonrider's Avatar
    Feb 2009
    Canby, OR
    Ron;
    Let me know what Part number(s) to order a complete oil change kit for my 2014 RT
    Thanx
    2014 RT SE6 Rider
    X - Honda Rider
    X - RT S driver
    X - RS driver
    Lifetime VFW Member
  5. #155
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Dragonrider View Post
    Ron;
    Thanx
    Just email me at fyredad@hotmail.com and we can proceed. If you want a price quote on Amsoil I will need a delivery zip code.
  6. #156
    Mar 2015
    NEW JERSEY
    Default BARJON SWAY BAR F3S
    I AM LOOKING FOR A PLACE TO ORDER ONE.
  7. #157
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default Spyderfest
    Ron will you be at Spyderfest??????
    14 RT-S , Stock Large brake pedal White Pearl
  8. #158
    Registered Users Andy Cserny's Avatar
    Nov 2011
    Raleigh Illinois
    Default oil seals
    I presume by the oil seals you are referring to are the gizmos Honda calls "crush washers", which, according to Mother Honda, MUST be replaced with every oil change. After 217,000 miles on my 1800 Gold Wing I am still using the original crush washer with nary a drop of oil having escaped so far. The O ring is an entirely different animal and I have replaced them at every oil change.
    I did get your sway bar and it with the Elka shocks has made a huge difference in how my new 2014 RT handles.
    Andy
    My wife and I circumnavigated the globe on our trimaran sailboat, gone 8 years
    Cushman Eagle, 1954 Corvette, 1964 Corvette with Duntov cam, 1996 Corvette, Chrysler 300 Hemi,
    2003 1800 Gold Wing with Hannigan sidecar
    2014 Spyder RT
    IBA41956
    DS446
  9. #159
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Andy Cserny View Post
    Andy
    People use the term 'Crush Washer' indiscriminately and really, this is the cause of confusion. The Spyder does not use crush washers (nor does Honda) for their drain plugs. Instead, a standard copper or aluminum washer is used and can be re-used indefinitely (contrary to what most people think) as long as it is not damaged.
    Below is an example of a true Crush Washer. Though they come in many forms, they all have at least 2 things in common. They are hollow and they cannot be reused because they are designed to deform (or conform) to the mating surfaces they are designed to seal. Hence, the term 'Crush' is accurate because that is exactly what they do.
    Below is a before and after picture of a genuine crush washer (not Spyder). As you can see, the crush washer is, well, crushed. It will not seal again. It must be replaced each time.
    This next picture is an example of the washers used in the Spyder, Honda and most other MC drain plugs. These are a standard, solid material washer. They do not crush. These can be re-used indefinitely. Though it is a good idea to at least have a new one handy when you change your oil just in case the old one is damaged.
    So, that is why you can re-use your 'Crush Washers'. It is because they are not!
  10. #160
    Registered Users mikedoucette66's Avatar
    May 2015
    Canada
    Ron
    I'm getting ready to have my 5000 mile inspection done by the dealership and need to know how much is the oil filter and tranny kit for an F3 with the semiautomatic 6 speed cost? And what all does the kit come with? Please and Thanks Mike 😆
    Sent from my SM-N900W8 using Tapatalk
  11. #161
    Very Active Member Sam Mac's Avatar
    Dec 2015
    Galax VA
    Just broke down and ordered the bar and shock adjusters for my 2014 RT Limited so I guess the "Farkling" has started. I'll probably do a belt tensioner also. After I get the Baja Ron stuff on it I need to take it to the dealer, it is showing the "Manual" thing on the dash for the air ride.
  12. #162
    Active Member telespec's Avatar
    Nov 2012
    Houston, TX
    Default Oil Change Kit
    Sorry if their's a post on this already but I need to know if you sell a oil change kit for a Spyder SE5 2012 RTS and what is the cost?
    2012 RTS SE5
    SpyderPops BumpSkid Guard
    PowerSportsWraps Phoenix Bird
    GloRyder Lights for Front Wheels with Remote
    Lamonster IPS
    PowerSportsWraps RT Dash Kit Woodgrain
    Custom Dynamics Chrome License Plate Frame
    Shortee Antenna
    Knight Riderz Light Bar Blue
    Front and Back Spyder Decal
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    Lamonster LED Headlights and Fog Lights
    LED Tip Lights
    LED Light Strips for Front Fenders
    LED Light Strips for Left and Right Turn Signal
    Third Brake Light for Rear
    2012 RTS , Blue
  13. #163
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by telespec View Post
    Yes, I sell filter kits (includes needed washers and O-Rings) for all Spyder models. The 2008-2012 SE5 Spyders are a bit tricky as they can have 1 of 2 different transmission filters. Most of them have been converted to the 'Extended' filter. But some still have the original transmission filter. Either filter works just fine as it was only the BRP filters that were problematic.
    To be sure which transmission filter you have you need to measure the length of the transmission filter cap. If the cap is 7/8" long, then you have the original filter. If the cap is 1-3/8" long, then you have the extended transmission filter. (See Picture) These transmission filters ARE NOT interchangeable.
    I also sell Amsoil for the Spyder at my actual cost, if you are ever interested. Since I sell it at my cost I need your zip code to give an accurate price quote. Delivery destination affects total price.
    Hope this helps!
  14. #164
    Nov 2012
    Houston, TX
    Default Oil Filter Kit
    Thanks Bajaron my zip code is 77498.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
  15. #165
    Aug 2007
    Greeneville, TN
    I PM'd you with a price quote.
  16. #166
    Nov 2012
    Houston, TX
    Thanks Bajaron I will get back to you.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
  17. #167
    Invalid Emails
    Feb 2013
    Castle Rock, Co.
    Hope this helps!
    Thanks Ron.. If anyone has hade an oil change at the Dealer the cap and filter would have changed to the new one
    once the new cap and filter came out I was not able to get the old filter and hade no reason to use the old style..
    your thoughts I will be looking to order engine and trans filters from you very soon, one more things THANK you for making it clear on the washers that's helps jtpollock
  18. #168
    Mar 2016
    Texas
    Default Thanks Ron
    Quote Originally Posted by effgjamis View Post
    I agree with your statement, however, I notice that you are not listing any ditch jumping devices.
    I enjoyed reading your thoughts on each product. I will be ordering from you soon.
  19. #169
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default Oil change kit
    What is the cost for a 2016 F3 Limited oil change kit zip = 47402
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
  20. #170
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by al0vely View Post
    The filter and seal kit is $12.95 delivered. I also sell Amsoil if you are interested but I am not allowed to list pricing here. Amsoil is a true, full synthetic oil and a superior lubricant. It ends up being about the same or a little more than the OEM oil an d filter kits.
  21. #171
    Active Member krafael5's Avatar
    loxahatchee, fl. 33470
    Default K and N oil filter
    Hi Ron, do you carry k&n oil filter for a 2014 Rts and how much for area code 33440. thanks
  22. #172
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by krafael5 View Post
    Yes, I carry K&N filters for all Spyder models. The K&N kit for the 1330 Spyder is $16.95 delivered.
  23. #173
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    hi do you make the sway bar & links to fit the new 2019 can am spyder f3s special series ?
    richie spyder
  24. #174
    Nov 2018
    hudson michigan
    Hi Ron will you have a area for the Ryker parts you are offering? thanks farmer54
  25. #175
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by ssmcclub View Post
    Yes, I make custom sway bar kits for all Spyder models and years. Soon I will have a sway bar kit for the Ryker.
