c.g.
As I mentioned in another thread, you have to jack at the rear hole in the underside of the RT frame to raise the rear tire. Apparently, the c.g. is just slightly forward of this point. Using a typical motorcycle jack with two cross slats, places the center of lift ahead of the c.g. and the front will raise first.
Dave
Never leave well enough alone! (Raymond Loewy)
RT-S PE#783
Lamont posted useful pics . . . . you might do a search for it.
Vaughn
Spyder Cat's other half
Passing thru Southern Oregon? Come ryde with us SOreSpyders@yahoo.com
2010 RT-SE5 PE#783
Mods: Corbin Custom Seat & passenger arm rests; Elka Shocks, RT622 trailer, and lots and lots of gas. . . . and did I mention, a new rear tire?
2010 RS , custom home made billet Red/Black
RT-S PE#0194
Spyder jack
I got mine from f1. I think it it's one of maybe a half handful that were made and shipped. It works good.
Vwatso
Hydraulic floor jack --
-- from Walmart for $19 used under the trailer hitch picks the back end up easily. I use it so that I can rotate the rear wheel while cleaning it. And speaking of the rear wheel, wouldn't it have been much easier for us if BRP had put the valve stem on the exhaust side of the wheel? Hiding it behind the drive belt doesn't make checking pressure any easier, especially for those of us who are anal about tire pressure.
Mod Maniac
Originally Posted by punji
...wouldn't it have been much easier for us if BRP had put the valve stem on the exhaust side of the wheel?...
Yes, except for the few who would get a lawyer when they get burned.
You could have a new 90* stem put in facing the other direction.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
