I got the amber after I saw them on photos that DAVE01 posted. I feel they define the front of the Spyder. The amber are also a little cheaper.
Thanks Jim - a.k.a. SpyderRider
"Experience hath shewn, that even under the best forms of government those entrusted with power have, in time, and by slow operations, perverted it into tyranny".
~ Thomas Jefferson
One of mine burned out, so I went into a truck stop and got 2 white long life with a number 97. They are considerably brighter than the stock. Why LL, they last a lot longer
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
I have white and they are very bright. They match the white LED's that are mounted lower front.
fender LED
I got the amber but I think the original white bulb was a lot brighter and covered a larger area. I could look down from the seat and see that the white bulb was on but I can't see the amber bulb.
YOUTH AND TALENT ARE NO MATCH FOR AGE AND TREACHERY!
went cheap for trial ... ordered last night from ebay the 5 LED 194 size bulbs for $1.50 shipped each
i figure if they don't work only cost $3 to try out.
they have 4 LED around outside an e one pointed straight out top of bulb so should light the fender tip brightly from all angles.
went with white as looking at the spec you get more lumen output from the white bulbs then the amber
RT-S PE#0412
ESI amber because they match my Double Play lights and my Fender tip reflector lights perfectly~~~!!
Sea Doo GTI-SE 90 Jet Ski!!
