Originally Posted by Big Arm
I did my dash turn signals a yr. and half ago after continually not self- canceling my signal after a taking a slight turn-off street near my home. I hated that "generic flasher for both sides" Mine are the red LEDs and the green LED is wired in to show when the fan turns on.
Your install looks real nice.
How much clearance is there behind the panel just on the lower left and right sides below the gauge cluster? I want to install two 12v cigar aux ports on mine but wasn't sure if there was enough clearance to do so.
I like the light for when the fan kicks on. How did you wire that?
Clean install BTW.
