Results 1 to 13 of 13
    Aug 2010
    Ironton Ohio
    Default 2010 RT trailer wiring
    Can the existing wiring on an RT be tapped into and ran thru an isolator circuit relays to tow a trailer other than the BRP trailer? Will this create computer problems for the VSS, ABS, etc.?
    Springfield, MO
    welcome
    You won't have any trouble with the computer, it's doesn't know you're towing a trailer.
    Apr 2010
    Milehigh City
    welcome
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    welcome Good luck with your wiring .
    Happy Owner
    Very Active Member dancogan's Avatar
    Jun 2010
    SE Michigan
    Wow, Lamont, that's great info. Does it come from the shop manual? I'll print that off and save it.
    Dan
    Springfield, MO
    Quote Originally Posted by dancogan View Post
    A member here posted it.
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    and welcome.
    Mar 2008
    Allegan, MI
    I am towing two different non-BRP trailers. Both have separate turn signals and 6-pole plugs. I bought the BRP Trailer Tongue Harness P/N 710002029, and built my own adapter. If you have a trailer without separate turn signals, you will need an additional converter. You won't need an additional isolator if you have the BRP hitch and trailer plug. The isolator module is already built in to the harness.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member rogerb's Avatar
    Jul 2010
    Waterboro,ME
    If you need a five wire to a four wire set up go to www.customcruiserchrome.com . Canadian company with good products and fast service. Shipping included in price. Also have trailerhitches.
    Registered Users wa3wheels's Avatar
    Federal Way,Wa.
    Default Converter ?
    I have wired my none BRP trailer using the wire diagram posted above. I used the BRP harness ... all works great .... BUT after about 15 miles the RT will go into limp mode and shut down, I stop and wait about 1 minute and it fires right up, it continues to do this so on this last trip to Ca. to Corbin I unhooked connector and ran with no trailer lites. My non BRP trailer set hight wise low enough that the Spyder lite can be easily seen from the rear. What did I miss in the wiring set up and you mentioned additional converter ( ) purpose and where would this be placed in the flow of the wiring?
    Thanks ahead.
    wa3wheels How can u drop a raw egg onto a concrete floor without cracking it? *Any way you want, concrete floors are very hard to crack.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by wa3wheels View Post
    Thanks ahead.
    I have had no such problems. Hard to diagnose your problem remotely. Do you have separate turn signals on your trailer? If not, that could be the source of your problem. You would need a 5-4 wire (3-2 wire) converter. Basically your circuits would be crossed at times. It could also be a short, too much lighting load...or even a non-related issue. When the Spyder goes into limp mode, you need to check the fault codes before you shut it down. If the problem remains, PM me and I'll send you my vitals so we can discuss it further, offline.
    -Scotty
    Ontario
    Default BRP trailer harness
    I own a Fibro Concept Trailer that I used with my Goldwing before trading it for the RT, a much nicer looking trailer than the BRP one. I bought the BRP trailer harness and wired it to my trailer, all works perfect. Just need to get the trailer painted to match the RT, thanks for all of the info.
    MOgang Member & Monster Member
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    You know, if there was ever a niche to be filled, some smart vendor should manufacture an adapter to plug into the spyder and connect to a four wire trailer system. No need to read and interpret a diagram. Just plug and play baby!
    I for one would purchase such an item!
