hanging helmet on spyder bike locks?
anyone figure a way to get more clearance to hang helmets on the two under seat hooks? the set hits the helmets and wont latch when helmets attached to hooks.
2nd WHY did they make them out of plastic?
i would think they will brake after a few years of use from stress...
I use these only when there is no room in any of the storage compartments for the helmets. I have been able to hang two full face Fulmers as well as two full face Arai Profile helmets without seat clearance issues. Generally, I put both full face helmets in the front storage compartment though.
Chris
The one on the left side already broke off.
helmet locks
Somewhere along the line I saw replacement handlebar end caps that had helmet locks built in. These looked very interesting, and a lot more substantial than the under-seat hooks.
Dave
Never leave well enough alone! (Raymond Loewy)
actually after reading this (sigh)
maybe best to strap both helmets together on one side only. put strap under seat and then shut seat. that way no way to remove helmets. have to see if straps would be long enough
we want to get as much storage as possible for 4 or 5 day trips. so storing in bike luggage is not an option
thanks for confirming they are useless
Motorbike Professor
I use mine periodically. Use depend a bit on the length of the helmet straps. Mine will fit (barely) but Nancy's small helmet won't let the seat close. There are solutions. The metal strap extenders made for that purpose are too rigid to allow the seat to close. A short loop made out of aircaft cable will do the job. So will a zip-tie, made into a loop. Even a piece of sturdy cord will do. Loop the extender through the D-ring, and hang the other end of the extender on the hook.
I prefer to use the frunk and right saddlebag for helmet storage if I can, but with luggage (or a cooler) that is impossible. The hooks are a good alternative, but they can break when the seat is pushed down, if the straps are too tight. Another alternative is the LidSafe helmet bag by PacSafe.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I made a short cable loop and hook it through the dring and the other end on the underseat hook. cumbersome but does make the hooks useful. Usually use the frunk for 2 full face jhc's as they won't fit the side saddlebags.
NO problem for me as this was one of the first mods I made. I asked the question about where to hook the helmets when fully loaded and I designed these easy to make SS aircraft cables, and they work great.
If made the proper length the helmets can rest on the rear footboards so the entire weight of the helmet does not put excess strain on the plastic. Heat shrink was used to prevent scratching the body work.
C-YA RL
helmet lock...
Here are a couple of locks that I am considering. Aside from mounting to the handgrips, they look as if they could be bolted to any hardpoint on the Spyder.
http://www.cruisercustomizing.com/de...d_name=fitment
http://www.cruisercustomizing.com/de...k_Kit___Chrome
The Kuryakyn comes in several mounting styles, one of which could probably be made to work on the Spyder.
Dave
the first one if you have heated grips wont work
you need the ISO grips installed. I have them on my Harley
they replace the end cap. but with the heated grips the ISO wont fit from what i understand
It appears as if they attach with 4 screws to the ISO grips, and some, for other bikes, seem to have a single bolt attachment. I haven't removed the end plug on the clutch side of the RT to see just what is inside. Experimentation is in order!
Oooops! just found this...
http://www.kewlmetalstore.com/produc...roducts_id=523
Dave
RT-S PE# 536
I can't get both helmets in the frunk without a lot of manipulation and tongue wagging. I now put my wife's in the frunk and use a pistol lock for mine and hook it under the seat. We are thinking of getting a couple of the Pacsaf Lidsaf bags. Waterproof and slashproof.
Jay on Omega Bay Texas
Spyder RT-S PE# 536
good to know the gun lock will work.. have a few of those around
also tried slipping the strap from one helmet through the D-Ring of the 2nd helmet. then slinging then across the Spyder under the seat and on top of the seat support strut ...
gun lock seems better soln.
interesting Pacsaf bags
http://www.pacsafe.com/www/index.php...n=detail&id=27
If they are full face helmets, put the first one in upside down with the chin guard facing diagonally aft and to the bike's left. The next helmet goes in on its side with chin guard facing left or right and the opening facing aft. If you have a Scala or equivalent mounted on the helmet, then the second helmet may only fit left or right. In my case, both of our helmets have Scala G4's mounted on them and the second one fits with the chin guard facing to the bike's right side. Do not force the trunk lid down...if you are having to do that, you do not have them in correctly or they simply may not fit. Helmet manufacturers vary shell sizes quite a bit. I have been able to do this with Fulmers (rather large shells) and Arai helmets. None of my helmets have been able to fit in the side cases as they are simply too tall.
Chris
Motorbike Professor
Chris
I thought that until I tried mine in the right saddlebag, laying on its side. The top of the helmet will stick out a bit, bit it fits in the recess of the lid.
-Scotty
Haven't tried that yet... Thanks for sharing.
Chris
helmet lock...
Originally Posted by sinkhole
I just spoke to KewlMetal regarding the Kewlocks for the RT. They will sell them separately @ $59.95 each. The part # for the clutch side is item 534.
Dave
Yep, fits in the R/H side bag just as Scotty described. I could not get it to fit in the L/H side bag though.
Chris
Motorbike Professor
Chris
Me either.
-Scotty
Motorbike Professor
Originally Posted by Gargoyle
Thanks for the link.
Another option is the PacSafe RetractaSafe retractable cable locks. They store easily, and you can make any size loop you want to extend your straps to the hook under the seat. You can even leave your helmet on the handlebars (I cover my GPS that way) and lock the helmet to the handlebars. Aerostitch sells a similar product. The longer version works for securering your riding gear, too (with a little scrunching of the fabric).
-Scotty
A group of people I ride with use handcuffs to lock on helmets or lock wheel of the bike or what ever. Just the fact that they are handcuffs people leave them alone.
