BRP Sport Rack Helmet Locks
I'm trying to install the sports rack helmet locks, but I read there are three screws holding the bottom on. I can only see two screws. If anyone can me where the third screw is, I would be thankful.
where did you find the helmet locks for the sport rack? think that would be nice to have/more trunk space
Look at the plastic piece just above the rear tire. There are 7 screws; three on each side and the 7th at the very top (which is I believe the third screw you are looking for).
I found it by accident yesterday. Someone here posted pictures; it's a homemade set up. I happened to find it at the top where the pictures scroll across. I cannot remember the screen name of that person. It looks good; but, I wouldn't one to keep lifting the backrest. Some members have had trouble with the pin coming loose and breaking tabs.
Here:
http://www.spyderlovers.com/forums/a...k+Helmet+Locks+
thank you that was the right screw. The cover slide aft that was the trick.
again thank you for your help
Here:
worked like a charm thank you very much for a great find....
Diggittt
Full Moon #1176
Talon Alarm
Trunk Spring
Power Bus
H.I.D. Headlights
Kuryakyn ISO Grips
NMN Highway Brackets
Kuryakan Highway Pegs
Two Brothers Dual Exhaust
BRP Sports Rack & Back Rest
LED Fender Tips
Ride-On
BRP Tank Bag
H.I.D. Fog Lights
Sirius Satellite Radio
GlowRyder L.E.D. W/Remote
TricLed Fender Lights
Just finished my installation of the helmet locks. GREAT idea
It did take a little grinding of the gridwork under the top cover to make room for the d-ring clearence, but no big deal. I measured about 10 times in different directions to get the placement to drill the holes, came out pretty close to where they need to be. All in all not too bad of an install. I did make a mistake and removed the 4 bolts inside the waterproof compartment, and took apart the whole thing before I realized that all I needed to remove were the three under the tail piece. One on each side and one in the center toward the seat. The part nos. and descriptions of the pieces needed for this from Home Depot were of great help and made it all that much easier. It cost under 5 bucks total!
Thanks again for the great idea!
Thanks for giving it a try. I should have posted the story here instead of the general forum. I finally made a trip after installing the locks a few weeks ago when I posted the photos. I had a cooler in the frunk so there was no room for my helmet and the lock came in handy as opposed to carrying the helmet around at every stop.
I am sure someone creative on the board can make a template and sell the kit on E-bay for $20.00.
I've never had a problem with just leaving helmets on the bike--- people generally just don't mess with such things.
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
1VENOM, how did you get enough clearance for the d-rings under the top to latch down without grinding away some of the web? The web on mine almost contacts the bottom when closed. It closed fine without the helmet, with just the posts installed, but with the d-rings around them it wouldn't close down far enough without grinding. Post placement wouldn't have made a difference. Maybe there is a difference in how tight the tops close or something?
Motorbike Professor
Also there are differences in D-rings from helmet manufacturer to helmet manufacturer. Just a thought...
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I only use one (1) D-ring to hang the helmets as shown in the pic below.
I have included another pic which shows the clearance I have with the Back rest locked down.
Catching a Yellow Jacket in your helmet at 65 mph can double your vocabulary
Alignment Specialist
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
Looking at everything, it appears this only works with the backrest and not with the sportrack cover.
