Page 4 of 4 FirstFirst 1234
Results 76 to 84 of 84
  1. #76
    Very Active Member tobor9's Avatar
    May 2011
    Charleston,SC
    Honda #18392-MAM-000
    2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips.
    tobor9@me.com
  2. #77
    Invalid Emails
    Dec 2012
    Tollison, AZ
    Default Y gaskit RSS
    Is the Honda part number for the Y gasket for the muffler??
  3. #78
    Mar 2008
    Allegan, MI
    Quote Originally Posted by master1309 View Post
    No, it is for the 2008-2012 GS/RS (upper) y-pipe gaskets. There is no Honda equivalent for the muffler gasket or the gaskets on other models. They have to be purchased from BRP.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  4. #79
    Active Member Joel's Avatar
    Sep 2011
    Mission, BC
    Changed both on my 2011 RSS today using Honda #18392-MAM-000, this post really made the whole process easy.
    Joel.
  5. #80
    Jun 2011
    Near Lexington, NC
    Default Mechanic said it takes 2 hours
    My RT is getting louder and while at shop the other day I asked the mechanic how long it took to replace them and he said 2 hours, but not to worry about it until it got louder or started to backfire. With 29K, I'll stretch it out a little longer and try to time it when some warranty work is being done to possibly save a few bucks. They're still trying to figure why I keep getting a "faulty brake" light so it'll be back in for more tinkering sooner or later. The $1000 VCM replacement didn't do the trick!
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  6. #81
    Apr 2010
    Montreal,QC
    Oil brake need to be top full. Oil level brake sensor is very sensitive.
  7. #82
    Apr 2010
    Montreal,QC
    Default Rt 2010 Slip joint pipe measurment
    Last edited by Peter Aawen; 08-12-2022 at 11:53 PM. Reason: Fixed attach & display
  8. #83
    Nov 2018
    Tonopah, AZ
    That is not the part number. That Honda part is about a 1/2" too small in diameter
    2018 F3L Cat Delete, Two Bros Pipe, Doc Humphreys Belt Tensioner and Pedal Extender, 17" Freedom Windshield, Spyder Extras Sway Bar & End Links
    2018 F3 Limited , Stock Doc Humphrys Intense Red
  9. #84
    Quote Originally Posted by QuadRAGIN View Post
    If you were answering " Mickay " !!!!!! ..... His post is over 5 years old..... good luck .... Mike
