Bootie-The Grievous Angel
2015 F3-S, ISCI Handbrake, F4 32" Windshield, Zumo 660 GPS, Sway Bar
Motorbike Professor
You are doing better than I am. My oil light stays on whenever the switch is connected. The switch goes to infinity and the wiring checks out, so that puzzles me. The engine seems to have good oil pressure (no knocks or strange noises), but I am leery of running it. I do not have the right connectors to do a wet oil pressure test. Odd that the code does not clear, even with the switch disconnected and the oil light out. I also had a code P0000 for a while, but that cleared when I disconnected the battery for 15 minutes. It is a phantom code that has no meaning in the book.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Hmmm. I don't know what to say. I I'd say you are doing the right thing by not pushing your engine to the limit. Looks like an oil gauge is required. I guess I'd take it to the Dealer.
Here ya go.
Originally Posted by Dwight
I have a fault code. Where do I find the explanation for them? I have an EDB fault, code P0524. Anybody have any ideas? I do have the CD shop manual.
Thanks
Dwight
https://powersportsguide.com/can-am-fault-code-list/
Well, he maybe late to the table, But I thank him for this info as I've never seen it before.
Thank you.
Adj removable backrest, KOTT radiator screens
Double horn (118db), Lamonster mirror fix
tender plug in, luggage liner/bags, FOBO 2
Drinks2go cup holder, replaced the seat strut
Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
White pulley, Pedal Commander
Laminar Lip- looks fonky but works.
J&M 2003 CB installed
Home made belt guard
7x12 enclosed trailer
2021 RTL Dark Chalk Metallic
Skip H.
Originally Posted by Tucsonspyder
Anyone know offhand how current and complete this list is for Spyders? It looks like it probably has the codes for all Can-Am vehicles, which I suspect include many not applicable to the Spyder. I'm thinking of copying the list and put it into a PDF and put it in the stickies section. The procedure for checking codes in the link does not apply to Spyders. It shows the procedure for a Maverick.
2014 Copper RTS
